my pony is shaking - Mustang Evolution
Old 07-22-2013, 09:47 AM   #1
skey's Avatar
my pony is shaking
So my wifes been driving my mustang as of late. She told me the car wasn't running right and that it was shaking when on the gas. So I toke it for a spin and it did it in fouth and fifth gears.I know I need to replace the air temperature sesnsor. Would that couse the car to shake like that and its getting worse. I checked the plugs and I need new ones soon but they aren't to the point they need replaving right away. I checked the gap on them and they was all gapped over .070. So I regapped them to .054. I went on a teat drive and its still doing it. Any ideas or in put would be great.
skey is offline   Reply With Quote
Old 07-22-2013, 10:27 AM   #2
austinknoll's Avatar
Misfire. Check your coil pack and wires
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 07-22-2013, 11:43 AM   #3
skey's Avatar
Found out its a bad wire I've had it a couple of months and the guy I got it form is dif not a car guy
Old 07-22-2013, 01:09 PM   #4
skey's Avatar
I'm slowly going throw everything on the car. I keep finding lil stuff other people over looked that needs replacing. About to do a full tune up oil plugs wires air filter wire everything. If I sea foamed it would that help with restoring a few lost ponys.
Old 07-22-2013, 02:29 PM   #5
Good idea. If you have the extra money, replacing your coil pack might be a good idea too. Sea foaming it definitely cleans out the intake if you put it through a vacuum line and put it in the gas tank to clear out the injectors. Also get a new fuel filter and get the transmission serviced. It's a whole different car after fluids and tune up
---------- Post added at 03:29 PM ---------- Previous post was at 03:28 PM ----------
If you have a manual obviously no need to get it serviced
65 Mustang coupe
Old 07-22-2013, 02:35 PM   #6
Project Pony's Avatar
If you do your coil pack I suggest the msd street fire coil pack. Cheaper than the motorcraft one, but better. I replaced a brand new motorcraft pack with one and couldn't be happier. I didn't expect much, so it was a pleasant surprise.
[SIGPIC][/SIGPIC]
Old 07-22-2013, 03:01 PM   #7
skey's Avatar
Thanks guys. It is a 5 speed I had it a week and the thorw out bearing went out so I changed that and put new gear oil in the trans. Its the msd street fire on am. Its goimg to be a work on here and there kind of thing. So the sea foam gos in the tank and a vacuum line any other place it should go.
Old 07-22-2013, 06:42 PM   #8
1/3 in the gas tank, 1/3 in the brake booster, and 1/3 in the crank case. Do this about 100 miles before your next oil change. Give it 15-20 minutes after you got it all in before you start it back up and blow all that crud out.
[SIGPIC][/SIGPIC]
05:20 AM
