Rear end - Mustang Evolution
Old 07-22-2013, 05:02 PM   #1
greenstang41's Avatar
Rear end
Would my v6 rear end hold up with the gt engine and trans
greenstang41 is offline   Reply With Quote
Old 07-22-2013, 05:10 PM   #2
Crowned1's Avatar
no. if you want to swap a GT motor you're going to have to swap over everything from the GT.
Crowned1 is offline   Reply With Quote
Old 07-22-2013, 05:25 PM   #3
davidcseifert's Avatar
Region: Arkansas
If you spend close to a grand on it sure lol
blower/new cam soon
Old 07-22-2013, 05:37 PM   #4
So it wouldn't hold at all
Old 07-22-2013, 05:41 PM   #5
Region: Arkansas
It will hold if you put more money into it than an 8.8 cost lol
blower/new cam soon
Old 07-22-2013, 06:44 PM   #6
Project Pony's Avatar
Pick up a complete 8.8 for 100-500 bucks. No sense having the 4.6 and a 7.5 with an open diff.
[SIGPIC][/SIGPIC]
Old 07-22-2013, 07:05 PM   #7
mummert_96v6's Avatar
It would hold up just for how long is the question
mummert_96v6 is offline   Reply With Quote
Old 07-22-2013, 07:28 PM   #8
You can drive with it, no problem. It won't last long if you have a heavy foot.
Old 07-22-2013, 07:46 PM   #9
As long as he doesn't let the clutch fly a lot with that heavy foot
Old 07-22-2013, 08:39 PM   #10
What year mustang rear ends can I get
Old 07-22-2013, 09:02 PM   #11
Anything from 94-04 will bolt in. Just the 99-04 rears are 3in wider in total then the 94-98 rears. They will still all bolt up the same though. My 96 has an 8.8 from a 2000gt bolted in with no problems at all
Old 07-22-2013, 09:10 PM   #12
http://fayetteville.craigslist.org/pts/3927837799.html
Would this work
Old 07-22-2013, 11:31 PM   #13
3.8Monster's Avatar
No, its not a limited slip/ posi track diff. You need to find one that is. Try finding one that came off an actual gt mustang. The whole point of it is.to get both tires.spinning.
3.8Monster is offline   Reply With Quote
Old 07-22-2013, 11:47 PM   #14
What year mustangs rear end work
Old 07-23-2013, 12:02 AM   #15
3.8Monster's Avatar
Anything from 94-04. Only thing different is that the 99-04 rears are 3 inches wider from hub to hub which gives the car a more aggressive look in my opinion. But it bolts up the exact same.
Old 07-23-2013, 12:04 AM   #16
Sorry about that ididnt look up
Old 07-23-2013, 08:27 PM   #17
It's fine I asked these questions when I bought my rear
Old 07-23-2013, 09:37 PM   #18
8.8 is kinda hard to find I was trying to run my v6 rear until I got it but it won't work lol
Old 07-23-2013, 09:55 PM   #19
Crowned1's Avatar
where I live you'll find one on CL every now and then. just gotta keep a look out.
Old 07-23-2013, 10:55 PM   #20
Idk too much about rear ends but is this a good one http://fayetteville.craigslist.org/pts/3876732803.html
Old 07-24-2013, 01:42 AM   #21
3.8Monster's Avatar
Nah, its off a foxbody. It Wont Bolt on. Try.calling a local scrap/salvage yard and see if they have a wrecked GT that still has a good rear. Just remember to make sure its within 1994 and 2004.
Old 07-24-2013, 09:04 AM   #22
It will bolt right in no problem. It's just foxbodys had 4lug and drum brake. Your best options are to find one from a 99-04 gt they were more common to have limited slip differentials
Old 07-25-2013, 01:04 AM   #23
Region: Arkansas
My friend is running a fox rear in his car, just need 94-98 length axles and transfer your disc brakes and other brackets over to it, it will tuck your wheels in .75" each side.
blower/new cam soon
10:09 PM
