**Serious problem** - Mustang Evolution
Old 07-24-2013, 11:55 AM   #1
813floridaracin's Avatar
**Serious problem**
I've just recently noticed this sound when I brake and occasionally when I step on the gas. It sounds like a taser(weird but concerning). Seems to be coming from my dash. Any help would be greatly appreciated. Should I be concerned with driving around. Does it need to be fixed, I'm short on money right now
813floridaracin is offline   Reply With Quote
Old 07-24-2013, 09:46 PM   #2
1slosix's Avatar
there are two wires going up to your brake light switch...they are notorious for burning out (i've had 3 '04 mustangs and they all had this issue). that tazer noise could be an arc passing between the wires if they are shorting. i'd check and see
carving corners like a boss
Old 07-24-2013, 09:47 PM   #3
1slosix's Avatar
here's how i fix them...i remove the box that connects the wires to the brake light switch...it's literally just two female wire ends inside the box (i took it apart to be sure)...i just spliced in un damaged wire and added female ends. cheap and nice fix for a frustrating issue to track down.
just make sure you put the two wires to the correct end lol
Old 07-25-2013, 01:07 AM   #4
Are you talking about the e brake light in the dash
Old 07-25-2013, 01:10 AM   #5
1slosix's Avatar
no this has nothing to do with the e brake
Old 07-25-2013, 01:12 AM   #6
Okay I understand everything your saying about the shorting and the arc. Just confused on the location of the two wires
Old 07-25-2013, 02:19 AM   #7
1slosix's Avatar
above the brake pedal at the switch
Old 07-25-2013, 06:17 AM   #8
Oh okay thank you so much, il take a look once the rain stops hopefully its that
Old 07-26-2013, 10:00 AM   #9
Should I be concerned driving around with this problem? Iv had brake failure before and I don't want to go through that again.
Old 07-26-2013, 11:59 AM   #10
Robbiemustang96's Avatar
Your brake lights wont work but shouldnt effect your brakes.
Robbiemustang96 is offline   Reply With Quote
Old 07-30-2013, 06:06 PM   #11
The brake lights seem fine, even as the taser noise is happening
Old 07-30-2013, 06:38 PM   #12
1slosix's Avatar
well there is for sure something grounding that shouldn't behind your dash. pop out the cluster and look behind it to see if you can spot burn marks on the metal
09:51 PM
