Mustang V6 Transmission Oil Change. - Mustang Evolution
Old 07-24-2013, 09:30 PM   #1
sebasflorez's Avatar
Hi, I need to change my Transmission oil, anyone know a tutorial?
sebasflorez is offline   Reply With Quote
Old 07-24-2013, 09:46 PM   #2
JimmyMosqueda's Avatar
Hope this helps.
JimmyMosqueda is offline   Reply With Quote
Old 07-25-2013, 12:48 AM   #3
Originally Posted by JimmyMosqueda View Post
While that video is informative and funny...
Do not use that additive **** lol. Just good quality motorcraft oil.
Nyke is offline   Reply With Quote
Old 07-25-2013, 08:12 AM   #4
+1 Don't use that cheap no brand stuff! Lol
Old 07-25-2013, 08:20 AM   #5
Thanks guys!
Old 07-25-2013, 08:32 AM   #6
No problem! Let us know how it goes!
Old 07-25-2013, 10:24 AM   #7
How do you change all of it. I did that to my old marquis but I want to change all my old fluid in mustang how would I do that
Old 07-25-2013, 10:52 AM   #8
Vsixpower's Avatar
I wouldn't suggest it if u are over 100000 miles it could possibly ruin ur tranny if u haven't been changing it every 30,000 miles...
Vsixpower is offline   Reply With Quote
Old 07-25-2013, 11:48 AM   #9
Project Pony's Avatar
Agreed. I mad the mistake on my 05 jeep wrangler. On the way home the transmission died!
Just have the do a fluid change, NOT A FLUSH.
[SIGPIC][/SIGPIC]
Old 07-25-2013, 12:24 PM   #10
Thank god you told me that my car has 113XXX miles and by the looks of things I can tell previous owner didn't change anything but I guess I'll just change filter
Old 07-25-2013, 12:35 PM   #11
After that many miles you don't want to knock all that built up crud around. Its sad that most people just don't know how to maintain a car. And you can never trust a previous owner sadly.
[SIGPIC][/SIGPIC]
Old 07-25-2013, 12:43 PM   #12
Vsixpower's Avatar
Right on point!!!!
---------- Post added at 01:43 PM ---------- Previous post was at 01:40 PM ----------
U can't get to the filter with out removing the pan n by removing the pan u remove the oil...
Old 07-25-2013, 12:49 PM   #13
I know the previous owner and he did change the transmission oil, only once though and she's 94k. Is it safe to change the oil anyways?
Old 07-25-2013, 01:22 PM   #14
At what mileage was it flushed?
[SIGPIC][/SIGPIC]
Old 07-25-2013, 01:25 PM   #15
Vsixpower's Avatar
I wouldn't just to be safe Id rather not take that risk but it all comes down to u..
Old 07-25-2013, 01:31 PM   #16
Vsixpower's Avatar
Theres two ways of change it either u take off the pan or use an evac to exchange it.
Old 07-25-2013, 01:39 PM   #17
Right on point!!!!
I know the procedure lol I just wanted to see if there was a way to get all the fluid out but the other guy scared me out of it
Old 07-25-2013, 01:47 PM   #18
Vsixpower's Avatar
There's one way u can take just the fluid out but it involves a evac machine that sucks it all out..
Old 07-25-2013, 01:49 PM   #19
That would involve going to those lube places but isn't that bad. I heard you can cause some serious damage if done wrong
Old 07-25-2013, 01:57 PM   #20
Vsixpower's Avatar
There's no damage that can come from it all it does,, sucks the old fluid out n puts new fluid in by vacuum easy process it only takes about 5-10 min n ur done...
---------- Post added at 02:57 PM ---------- Previous post was at 02:55 PM ----------
The only way it can cause harm is by not using ATF...or the proper fluid recommended...
Old 07-25-2013, 02:14 PM   #21
He said 45k.
Old 07-25-2013, 02:33 PM   #22
This process can, and does cause problems on higher mileage cars. You loosen a good bit of debris. If its has not been done every 30k its quite a risk to take. A drain and fill is all that should be done. Go to a reputable shop that specializes in transmissions.
[SIGPIC][/SIGPIC]
11:59 AM
