Windstar swap peeps.. - Mustang Evolution
Old 07-24-2013, 09:34 PM   #1
slow281
sixpac's Avatar
Region: Nebraska
I'm looking for a template for the relocation brackets.. Pictures, measurements, and tracings.. Anything would be greatly appreciated..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 07-24-2013, 09:45 PM   #2
samuelsmith's Avatar
G10 intake spacer is the hardest to find. If you cut a 1/2 metal plate it will be just as good.
What do you mean exactly by relocation bracket?
Old 07-24-2013, 09:52 PM   #3
slow281
sixpac's Avatar
Region: Nebraska
TB cables/coil pack/ iac what's the intake spacer for?
2001 GT - True Blue
Old 07-24-2013, 10:15 PM   #4
David should be able to hook you up with some of the parts. I can not speak on his behalf. But I would write him.
The Windstar van has a different fuel injector rail and fuel pressure sensor. So 1/2" of height needs to be added with a intake spacer.
Unless you can plastic weld you will need a throttle body spacer.
Throttle cable extender
The coil pack mount and throttle cable mount should be easy as cutting metal, drill holes, and bend with a pair of plyers.
The cai can be fabricated at a muffler shop with a pype bender. I can elaborate in-depth on this is just a beginner introduction to let you know what to do.
The iac relocate : I will find you a pic
Old 07-24-2013, 10:33 PM   #5
slow281
sixpac's Avatar
Region: Nebraska
You only have to bend the fuel rail a bit..
2001 GT - True Blue
Old 07-24-2013, 10:40 PM   #6
The Monster is kicking in! Just remembered where I saw a write up at. Check this link out n come back.
Windstar Intake Swap Questions? Look Here - Ford Mustang Forums
Did not know about the fuel rail bend. Read about the swap in 2006.
The easiest way to do the throttle cable is. Build the throttle cable mount. Cut a extra throttle cable a few feet from the end. Crimp the two throttle cables together and put some JB Weld between the 2 for extra protection.
Old 07-25-2013, 01:13 AM   #7
davidcseifert's Avatar
Region: Arkansas
Here's the cable bracket, it's just attached to the VAP coil bracket I had previously. No need to modify throttle cable if you're making your own brackets, you can make them to fit right.
(Note: the second picture is not mine, it's a friends)
ID:	120391   Click image for larger version
blower/new cam soon
Old 07-25-2013, 08:25 AM   #8
slow281
sixpac's Avatar
Region: Nebraska
With the way you have this set up, what did you do with the iac..
2001 GT - True Blue
Old 07-25-2013, 02:29 PM   #9
I just found a pic off the internet. The iac is relocated with 2 pieces of metal. Both are the same size and fit on the back of the iac and one where the iac mounts. The metal has 2 small 1/2 pipes that are welded on the left and right side that connect with vacuum hose.
Wait, you wield 1/4 pipe 1/2" long and drill a hole. Probably easier to buy vaps parts unless you have practice welding.
08:20 AM
