Changing Suspension and Springs '02 V6 - Mustang Evolution
Old 07-25-2013, 10:28 AM   #1
sebasflorez's Avatar
Anyone have a good tutorial or write up of how to change the shocks and struts and springs for a 2002 mustang? Any help appreciated!
sebasflorez is offline   Reply With Quote
Old 07-25-2013, 10:57 AM   #2
andregayola's Avatar
there are videos in you tube that can really help 1aauto is good at showing videos
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 07-25-2013, 11:06 AM   #3
Thanks man!
Old 07-25-2013, 11:10 AM   #4
the rear are easy just unbolt the strut or hock from the a arm n then slowly jack the axle down with a jack be carefull not to go to low or you snap your brake lines next you poke the spring with a crow bar or something to see if its loose n if it is take it out now the front are the hard part because its more difficult to remove te bolts i would suggest pb blaster and a good wrench/ratchet n lowering the front a arm you have to be very carefull not to brake those lines
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 07-25-2013, 11:50 AM   #5
1slosix's Avatar
I'm pretty sure I have a write up somewhere on here lol.
carving corners like a boss
Old 07-25-2013, 02:35 PM   #6
Anyway you could give me the link? Thanks
02:52 AM
