Mass air flow sensor - Mustang Evolution
Old 07-27-2013, 09:40 PM   #1
greenstang41's Avatar
Re the v6 and gt the same
greenstang41 is offline   Reply With Quote
Old 07-27-2013, 09:49 PM   #2
sam62893's Avatar
Doubt it. GT demands more air than the V6 is my guess
Old 07-27-2013, 10:12 PM   #3
samuelsmith's Avatar
no, but you need it to be smaller to create proper suction
Old 07-28-2013, 02:57 AM   #4
davidcseifert's Avatar
Region: Arkansas
V6 75mm housing
Gt 80mm housing
With as many threads as you post about V8 swaps you could have done one by now lol
blower/new cam soon
Old 07-28-2013, 11:17 AM   #5
Originally Posted by davidcseifert View Post
V6 75mm housing
Gt 80mm housing
I read on allfordsmustang it does not do any good to go bigger. Was the information misleading?
Old 07-28-2013, 11:28 AM   #6
Region: Arkansas
The maf just like injectors or a fuel pump are supporting mods and don't need to be upgraded unless they can't handle the power
blower/new cam soon
Old 07-28-2013, 11:42 AM   #7
Greenstang here is a v6 to v8 sticky of another sight.
96-98 or 99-04 3.8 to 4.6L - All parts listed are 4.6 specific unless noted. Use parts from the sub group your car is in; 96-98 or 99-04
Complete engine - pan to throttle body
Throttle cable
Air intake
MAF
Engine accessories w all brackets, lines, wiring, hoses
Motor mounts
Complete exhaust
Radiator & hoses
Fan
Overflow
EEC with harness
All engine wiring harnesses
Dash harness (?)
Speedo cluster
CCRM (constant control relay module)
Hydroboost brake booster with all lines - the vacuum booster is too big and will not clear the 4.6
Transmisson - You need a 4.6 transmission. They had 4.6 specific bellhousings built into the case..... even on the manual transmissions.
Flywheel and clutch for T-45 and 3650 manuals
Flexplate for 4.6 auto trans 4R70W
Driveshaft - 4.6 has a specific yoke that is not the same as any 3.8 yokes. Tubes are the same length, in case you want to swap only the yoke.
02:20 PM
