Quadrant - Mustang Evolution
Old 07-28-2013, 08:13 AM   #1
Chapka's Avatar
Quadrant
So I'm looking to replace the clutch quadrant. Is it that hard of a project? From the re search I did online it doesn't seem to hard, but i dont know. Any tips or advice on the replacement?
America is all about speed - hot, nasty, badass speed
Chapka is offline   Reply With Quote
Old 07-28-2013, 09:10 AM   #2
97cutomstang's Avatar
I just did mine a couple weeks ago and it's not bad at all. I took my seat out so I could lay down to see what I was doing better.
97cutomstang is offline   Reply With Quote
Old 07-28-2013, 10:32 AM   #3
Chapka's Avatar
That's a good idea. Would you recommend the BBK clutch cable kit? The video they show, doesn't require the springs to be put back. Is that a pro or con would you say?
Old 07-28-2013, 11:02 AM   #4
samuelsmith's Avatar
Do not expect a better clutch response. This is proactive move because some of them break. Most people do this when they upgrade to a stage one clutch. IF you get a stage 1 clutch eventually you will need a firewall adjuster also.
Old 07-28-2013, 11:26 AM   #5
I got the steeda one which is pretty much the same thing, and I did not have to put the spring back in.
Old 07-28-2013, 11:58 AM   #6
Chapka's Avatar
What new quadrant would you suggest? Should I look for one that's gonna re use the springs?
Old 07-28-2013, 12:07 PM   #7
I've never seen one that reuses the spring. I've only seen the bbk and steeda one. So I can't really help you there.
Old 07-28-2013, 12:50 PM   #8
The pressure plate has enough tension to retract the cable.
Old 07-28-2013, 09:41 PM   #9
1slosix's Avatar
^ yep...
no need to re use any parts from the old setup
carving corners like a boss
Old 07-29-2013, 02:59 AM   #10
Chapka's Avatar
Alright. That's for the help guys. I'll let you know how it goes
06:19 PM
