3.8 v6 catless? - Mustang Evolution
Old 07-28-2013, 09:28 AM   #1
Dlahu95's Avatar
3.8 v6 catless?
Should i remove cats or no? My car isnt really a performance car , i like cruising w it, but does removing cats really RUIN your gas milage? Does it also have a long term effect ppl often overlook or ignore? Such as stress on the engine or something like that? I have a 99 v6 3.8L that only has a SR performance cold air intake
Dlahu95 is offline   Reply With Quote
Old 07-28-2013, 09:31 AM   #2
slow281
sixpac's Avatar
Region: Nebraska
There all for sound, if you want it louder remove them
And ps try and use the search bar.. There was a thread just like this, a lot of bickering from a few immature members which I'm sure you may get a little here, but in the end I think there was a little info.
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 07-28-2013, 09:44 AM   #3
Dlahu95's Avatar
Yea i saw a bunch of arguing lol thought someone might just answer my questions upfront after all that bs. Wb gas, the engine, performance, etc.
Old 07-28-2013, 09:58 AM   #4
samuelsmith's Avatar
Your IRMCs will not work properly and the car will run a little rich. The IRMCs are located in the lower intake and recycle exhaust emissions. I ran without cats and gained a little hp. I now run with shorty cats and recommend them. The sound is not as good but the car seems to respond better.
Old 07-28-2013, 10:32 AM   #5
Crowned1's Avatar
just do it. I'm not arguing this. Everyone who has their cats off on a v6 will tell you to do it. I have mine off along with divorced Flowmaster 40s, sounds amazing, runs great. You'll love it.
Crowned1 is offline   Reply With Quote
Old 07-28-2013, 10:43 AM   #6
slow281
sixpac's Avatar
Region: Nebraska
Aka yes there is a little bit of effect not bad mostly noise..
2001 GT - True Blue
Old 07-28-2013, 10:46 AM   #7
I just did not have a tune. The smell got bad in Vegas. The west coast needs more green.
Old 07-28-2013, 11:35 AM   #8
Dlahu95's Avatar
What are shorty cats? Whats the differance?
Old 07-28-2013, 11:48 AM   #9
You have 4 cat. converters on your car. Shortys are a smaller version of a cat and you only need two. Pipes dynoded them with and without and you almost get the same results. The sound with out cats is loud and a cop attention getter. I had to cut my pipes short when I was without cats because of neighbor hood complaints.
Old 07-28-2013, 12:26 PM   #10
Dlahu95's Avatar
Do they pass the inspection? Bc im in NY So idk how far that goes. So shortys seem like a better idea for me bc theyr not as loud. Anything else about the shortys are differant than the regular cats? Effect on car/engine? Gas milage?
Old 07-28-2013, 04:55 PM   #11
Pypes Exhaust Systems Mustang 3.8L V6 Performance Parts FREE SHIPPING!
Look at the second pic. and read. Rember this is market hp so it will be more like 10-15 bhp and 15-20 with a tune.I am guessing hp so please do not make me dyno prove.Every mod. counts. I will take constructive intuition. They are 50 state legal and not sure about current California emissions. If you don't buy Pipes and get the same basic setup expect about the same results. Shortys basically flow better freeing up hp. Expect the same gas milage unless you get a tune. If you get a tune the m.p.g. will improve slightly and have a better response.
My uncle owns a Minakee and taught me this.
You will throw a check engine light. This does not mean any thing is wrong with your car. You have 4 o2 sensors. All adjust gas mileage. The back 2 also make sure the cats are not clogged. Basically it sends a different frequency to the comp. if the cats are removed and a check engine light comes on. The factory computer hates learning curves lol.
4 options:
1.The light means noting and my system is ok. Let it stay on.
2.Pull out the cluster and remove the bulb.
3.Buy mill eliminators.
4.Turn the signal off with a tune.
« 98 rims | 98 v6 »
10:33 AM
