Vacume question - Mustang Evolution
Old 07-29-2013, 03:02 PM   #1
97cutomstang's Avatar
Vacume question
I just installed a P&P upper intake on my car and it does not have the port where the break booster vacuum line connects to, so I connected it to the port under the upper that the passenger side valve cover vent would normally go. So my problem is where can I now connect the valuable cover vent tube to so it sill has vacuum?
97cutomstang is offline   Reply With Quote
Old 07-29-2013, 03:17 PM   #2
samuelsmith's Avatar
You do not need to. Some people put air filters on or split the vacuum with a t.I'll see if I can find a pic Hp report. Do you feel faster?
Old 07-29-2013, 03:19 PM   #3
Originally Posted by samuelsmith View Post
You do not need to. Some people put air filters on them.I'll see if I can find a pic Hp report. Do you feel faster?
Ok cool. Thanks. Haven't had it out yet. I'll have it out tomorrow after work. I'll let you know.
Old 07-29-2013, 03:31 PM   #4
If you can not find an air filter put a T vacuum on it. It's basically a splitter for vacuum lines. The line will slowly drip oil without an air filter. Btw no big rush to fix.
Who ported it?
edit: I can not say that was a mouthful lol.
1/2" vacuum line T splitter
02:00 PM
