Painted upper intake. - Mustang Evolution
Old 07-31-2013, 01:16 PM   #1
Robbiemustang96's Avatar
Hey guys, im tired of the bland non painted upper intake. Question i have is can i paint it with spray paint? Or do i have to get it powder coated since its aluminum
Robbiemustang96 is offline   Reply With Quote
Old 07-31-2013, 01:33 PM   #2
Mustang81596's Avatar
I'm pretty sure you can use VHT spray on it. Just make sure the can you're buying says engine enamel or I believe you could even use caliper paint because that's also good up to 9000 degrees
pypes x w/flow 40's, SR CAI, plasti dipped (emblems, stripe, rear decklid, rear valance, cowl vent grille, fuel door, antenna holder), shorty antenna, mach 1 chin spoiler, custom interior trim, blue LED interior lights, more to come later
Mustang81596 is offline   Reply With Quote
Old 07-31-2013, 01:48 PM   #3
9000 DEGREES!!! Do brakes even get that hot?! And thanks. What is VHT spray?! Can i buy it at autozone?
Old 07-31-2013, 01:53 PM   #4
SoberGT's Avatar
VHT is just the brand of one maker. They have others that make it too. You can get it at autozone, pepboys and just about any other auto parts store here's the VHT website
http://www.vhtpaint.com/
SoberGT is offline   Reply With Quote
Old 07-31-2013, 01:57 PM   #5
Sobers right. That's just one of the main brands. I bought this stuff from autozone for about.. $12 I wanna say? Something like that. But Oops, typo. I meant 900 lol
Old 07-31-2013, 02:11 PM   #6
I was gonna say lol do they still get 900 degrees? Uhm will this paint have any trouble adhearing to the aluminum?! Do i have to primer it first?
Old 07-31-2013, 02:23 PM   #7
I don't think so lol. Only if they're seized they start getting hot. And I do not believe it will as long as you do all the proper prep work. Primer is not necessary but doesn't hurt I suppose
Old 07-31-2013, 02:43 PM   #8
So i should obviously get all of the dirt and grease off it first but what else needs to be done
Old 07-31-2013, 02:45 PM   #9
SoberGT's Avatar
Yeah definitely do the prep work. The cleaner you get it before you do it the better it will be and longer it will last. No need for primer just make sure it's extremely clean and would wont have a problem.
Old 07-31-2013, 03:13 PM   #10
samuelsmith's Avatar
You can paint the throttle body. Just cover it up properly.
Old 07-31-2013, 03:28 PM   #11
97cutomstang's Avatar
I used caliper paint on mine.
97cutomstang is offline   Reply With Quote
Old 07-31-2013, 06:18 PM   #12
Not trying to jack your thread, but while we're on the topic I figured I'd ask how to clean really badly corroded manifold? Cuz I'm sure the paint wouldn't stick to it..
Old 07-31-2013, 06:21 PM   #13
I would use a good wire brush on it then just blow the dust off.
Old 07-31-2013, 06:31 PM   #14
sam62893's Avatar
That's a beauty... Did you use a brush for the blue? Do you have any pics of it on the engine itself?
Old 07-31-2013, 06:31 PM   #15
Alright. Cuz it's crazy bad, I've never seen one in this kinda shape haha
Old 07-31-2013, 06:33 PM   #16
Mines pretty bad too.
Old 07-31-2013, 06:41 PM   #17
Thanks. Yea I used a brush on the whole thing sorry the picture is kinda dark. I'll get a better one tomorrow.
Old 07-31-2013, 07:34 PM   #18
Thank you for a new idea! Just paint the whole engine lol
Old 07-31-2013, 07:50 PM   #19
Yea man. Go for it. I had the motor out so I figured why not.
Old 07-31-2013, 08:45 PM   #20
Oh you had the motor out.. That explains it,, can i do it with the engine in or does it have to be pulled
Old 07-31-2013, 08:51 PM   #21
You could do most if it but you won't really be able to get to the block its self. You just have to do a lot of masking off stuff. But it could still look good if you took your time.
Old 07-31-2013, 08:52 PM   #22
Get a flap wheel(like pic.) polish the lower part of the upper intake while its out and gain 5hp. Don't forget to pressure wash the intake afterwards. Yea, all about easy hp gains
Old 07-31-2013, 09:45 PM   #23
what does that do?
Old 07-31-2013, 10:07 PM   #24
what does that do?
It is like port and polishing. But you are only polishing.Any one can polish because all the flapper wheel does is give it a mirror like finish. Air will travel faster. It creates a swirly/vortex like effect forcing more air into the combustion process. Producing more hp. The computer can do small learning curves in this area without a tune.
Old 07-31-2013, 10:22 PM   #25
1slosix's Avatar
i painted mine in plastidip a few months ago....so far no issues and love the finish lol
carving corners like a boss
Old 07-31-2013, 11:30 PM   #26
andregayola's Avatar
I painted mine along time ago lol when I first bought the car
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 08-01-2013, 05:27 AM   #27
2000stanguy's Avatar
I cleaned my manifold with busch aluminum wash they have 3 levels of strength I used the heavy duty one! Here's what it looks like but I think I'm going to now polish it with sandpaper down to the polished aluminum. Also don't get this on a cai or on your alternator and it leaves like white spots on it that I used a brush and tooth brush to rub off.
Performance Red 2000 v6- m112 supercharger,42lb green top injectors, 310lph fuel pump, BBK shorty headers, True dual exhaust, strut tower brace, GT rear sway bar, Steeda triax short throw shifter, SR lowering springs, tinted headlights and foglights, polk audio speakers, MTX subwoofer, Kenwood head unit and black leather interior.
2000stanguy is offline   Reply With Quote
Old 08-01-2013, 05:49 PM   #28
Personally do not prefer the Ford silver rebuilt color. I Going to go back and do a orange n blue.
Old 08-01-2013, 08:22 PM   #29
Here's a good pic of mine on the engine
ID:	121646   Click image for larger version
Old 08-01-2013, 08:36 PM   #30
You even painted your valve covers!?
Old 08-02-2013, 05:43 AM   #31
Yea. Almost everything is painted.
Old 08-02-2013, 10:26 AM   #32
Crowned1's Avatar
I like.....Im gonna do mine. did you take the manifold off or just cover everything around?
Crowned1 is offline   Reply With Quote
Old 08-02-2013, 04:39 PM   #33
sam62893's Avatar
How did you paint the alternator and ac compressor?
Old 08-02-2013, 05:12 PM   #34
I split the alternator apart in to two halfs,and taped off the coils inside. And I just painted the compression I put tape behind the pully so I could paint the front blue ad keep the back part black.
02:16 AM
