I need help!! - Mustang Evolution
Old 07-31-2013, 06:30 PM   #1
bkh1994's Avatar
I need help!!
Okay so today I got some painted shorty headers put on. Afterwards the paint burned off, which was expected and is not a problem. BUT then the whole way home the car would lurch constantly. It also was making weird noises. The service engine soon light would flash on and off every now and then also. Just to see if it affected performance, I floored it and it did fine up to 60 (but lurched the whole way to 60) and then at about 60 the car accelerated SUPER slow, the RPMs also went up slowly. It took about 1 minute to get from 60 to 75 at WOT. Please help I dont know what is wrong
bkh1994 is offline   Reply With Quote
Old 07-31-2013, 06:33 PM   #2
Mustang81596's Avatar
Is everything sealed properly? Is there a leak perhaps
pypes x w/flow 40's, SR CAI, plasti dipped (emblems, stripe, rear decklid, rear valance, cowl vent grille, fuel door, antenna holder), shorty antenna, mach 1 chin spoiler, custom interior trim, blue LED interior lights, more to come later
Mustang81596 is offline   Reply With Quote
Old 07-31-2013, 06:35 PM   #3
sam62893's Avatar
What brand were they? Cheap brands can have leaks everywhere, heck even BBK has been known to have leaks. Did they put new gaskets?
Old 07-31-2013, 06:39 PM   #4
bkh1994's Avatar
They checked the seals and leaks before I left.
They are pacesetter. And yeah both were new gaskets
Old 07-31-2013, 10:09 PM   #5
NewMtang's Avatar
Tune?
Do you have a tune on your car? I don't know if it would make that much difference but I see no one yet asked. GOOD LUCK ON GETTING IT FIXED.
Old 07-31-2013, 10:10 PM   #6
bkh1994's Avatar
Nope no tune. But thanks though!
Old 08-02-2013, 11:52 AM   #7
bkh1994's Avatar
Some kind of plug wasn't in all the way so that fixed MOST of the lurching but it is still really slow. Any ideas? He tried to tell me that I might need a tune up and to run synthetic oil. But I think he just doesn't want to admit that he messed something up. The car ran FINE, none of these problems were present before they worked on it. Do y'all think that is really the problem? I just had my oil changed so I don't want to do it again if he's just bs-ing me
Old 08-02-2013, 04:38 PM   #8
sam62893's Avatar
Don't go to him if he can't even find out what's wrong. I suggest you go through and tighten an torque all the bolts to specs. Check the headers for leaks Jack the car up from the front, start it and check for any exhaust leaks, then jack the car up from the rear and do the same. Just careful not to touch the pipes if none of that works try doing a tune up minus the oil change since you just did it. Next check your fuel. Might be some bad gas
Old 08-02-2013, 05:42 PM   #9
1shotkllz's Avatar
Flashing check engine light usually means a missfire. Check your connections and plugs. O2 sensors as well
1shotkllz is offline   Reply With Quote
Old 08-02-2013, 06:28 PM   #10
bkh1994's Avatar
The bolts are tightened good and I'll take it to an exhaust shop about the leaks. But it's not bad gas or the tune up (yes it probably needs it but that's not the problem). I am on the same tank of gas as when he put them on. The car was absolutely fine before he put my headers on and now it is doing those things. Also a little of an update, it is still lurching/jerking but not near as much. And thanks for the advice!!
On the 3rd pipe from the driver's side (the farthest one) the paint is pretty much all still on. So I don't THINK it is firing on it. I'm not sure what connections and plugs to check, could you explain? Thanks for the time and help!
Old 08-02-2013, 06:30 PM   #11
1shotkllz's Avatar
Make sure all your spark plug boots are pushed down tightly. Make sure your coil pack is secure. He could of bumped/removed something and not put it back right.
Old 08-02-2013, 07:06 PM   #12
bkh1994's Avatar
Thanks I'll try my best to figure it out
Old 08-02-2013, 08:31 PM   #13
1shotkllz's Avatar
Let us know what you do and how it turns out. I'm a v8 guy, so know very minimal about 6ers. But every little bit of info helps
Old 08-02-2013, 08:44 PM   #14
Ubnbit's Avatar
I wish we had a pic to post for him. It would make it a lot easier to know what he is looking for. If there is still paint on that header tube, it is probably not gettin fire. Do u know what all he did to put ur headers on? Did he remove the plugs and or wires? I think the guys are dead on. Just look for ur spark plug wire on that tube and check it out. U might even pull the plug if the wire is on it good now. He might have pulled the plug and closed the gap.
Old 08-02-2013, 09:15 PM   #15
Blovett55's Avatar
MAke sure each boot is going to the correct cylinder too, you can't just unplug the boot and plug in wherever you feel so make sure theyr in order
Blovett55 is offline   Reply With Quote
Old 08-02-2013, 09:20 PM   #16
1shotkllz's Avatar
+1 firing order is everything
Old 08-02-2013, 11:15 PM   #17
bkh1994's Avatar
Anything else I can think of I will post
Yeah a picture would be helpful. I'm new to cars so I'm still learning. No clue what all he did. I know he had to pull out my power steering cause I heard him say it, other than that I have no idea. I will have a look at it. I'm taking it to Autozone tomorrow for codes, I'll ask them if they could check my sparkplugs real quick too.
Thanks! I'll try to figure out if they are right
Thanks everyone for their help!
Old 08-03-2013, 02:52 PM   #18
bkh1994's Avatar
Just changed a spark plug and that was the problem! It had a hairline crack down the whole thing and one of the little ring things was broken too. Thank you all for the help!
Old 08-03-2013, 02:56 PM   #19
1slosix's Avatar
Sounds like it was hit when the headers where installed.
carving corners like a boss
Old 08-03-2013, 02:58 PM   #20
bkh1994's Avatar
That's what I figured
11:04 PM
