Need help! - Mustang Evolution
Old 08-01-2013, 07:46 AM   #1
2Greeny7's Avatar
Send a message via Skype™ to 2Greeny7
Exclamation Need help!
Tech Question here!!!
Ok so today I put in some friction modifier to help get rid of my rear gear whine... and it worked (whine is a lot quieter) When testing the whine on the highway I noticed a nasty vibration at like 70+ worse above 70, I didn't dare go over 75 because it was nasty! Shook the whole car! Also when letting off the gas at like 70 makes a wooooshhh sound but almost grindy... Odd!
So! I need your help trying to find the problem! I will recheck to make sure all of my lugs are tight. Next Ill make sure my rear tires have weights on them so their balanced... After that... I'm lost! My other ideas are Driveshaft/Ujoint problem... Or wheel baring is shot...
Not sure! Could use the help!
2001 V6
CAI, SF3/X3 Tuner, 4.10 Gears, Auburn lim-slip
GT4 Rims (Summer), Stock Rims (Winter)
2 Subs, New speakers all around
1 Great Car 1 Happy Kid
July '12 Mustang of the Month
2Greeny7 is offline   Reply With Quote
Old 08-01-2013, 08:13 PM   #2
2Greeny7's Avatar
Bump I need to fix this!
2001 V6
Old 08-01-2013, 10:23 PM   #3
sam62893's Avatar
Does your whine sound like this? http://youtu.be/EE1u3GKndao
Get to the end where the car is slowing down at the end of the track. That's my rear bearing going out. Mine doesn't shake like yours does. I had a rear u joint bad and it shook at 49 but went away after 50 but never anything that seemed that dangerous
Old 08-02-2013, 01:24 AM   #4
Venomouz831's Avatar
Had the problem when I changed my clutch. If you had to remove the drive shaft then it's most likely what it is. Make sure it's nice and tight. We had to use lock tight on mine
)02 Gt, Founder of WE2G
Old 08-02-2013, 07:57 PM   #5
2Greeny7's Avatar
Will check out both things in the morning! Thanks guys!
2001 V6
07:09 AM
