Shocks and Struts - Mustang Evolution
Old 08-05-2013, 09:18 PM   #1
Blakhwk's Avatar
Shocks and Struts
My Stang hits 112k and still has the factory shocks and struts, I'm looking to replace them but I'm confused with the different brands and types out there that I don't have experience with.
From your experience guys, can you advice me for a good quality brand that is not so expensive and not cheap, something balanced between the quality and the price for a daily driver.
And anything else I should replace while replacing the shocks and struts?
Thank you in advance.
Blakhwk is offline   Reply With Quote
Old 08-05-2013, 09:26 PM   #2
1slosix's Avatar
tokico blues are the best bang for the buck out there
carving corners like a boss
Old 08-05-2013, 09:29 PM   #3
Venomouz831's Avatar
Tokikos and konis
)02 Gt, Founder of WE2G
Old 08-05-2013, 09:31 PM   #4
samuelsmith's Avatar
If it is not broke don't fix it
Old 08-05-2013, 09:48 PM   #5
Blakhwk's Avatar
thanks I'll check it, I guess AM have them.
Old 08-05-2013, 09:58 PM   #6
Blakhwk's Avatar
Originally Posted by Venomouz831 View Post
Tokikos and konis
thanks, I'll check both of them and compare.
---------- Post added at 11:58 PM ---------- Previous post was at 11:56 PM ----------
its not broke but it does not ride smooth.
Old 08-05-2013, 11:02 PM   #7
1slosix's Avatar
Worse advice when it comes to suspension lol. Shocks and struts should be looked at for replacement every 50-60k miles. Just because they aren't broke doesn't mean they are performing correctly. They effect everything from ride to handling to stopping distance even. Keeping them strong is the best thing you can do.
Old 08-06-2013, 09:45 AM   #8
Blakhwk's Avatar
my uncle was telling me the same thing, thats why I decided to replace it.
Old 08-10-2013, 03:00 PM   #9
Dlahu95's Avatar
Does anyone know if MACH 1 springs can go on a 99 v6 3.8? If so does that mean itll lower ? And how much is it to install springs?
Dlahu95 is offline   Reply With Quote
Old 08-10-2013, 03:16 PM   #10
sam62893's Avatar
Yes they'll fit perfect. They have a higher spring rate and the V6 is lighter so it won't give you much of a drop. How much? I don't know but it's a pretty easy install
Old 08-10-2013, 03:55 PM   #11
1slosix's Avatar
Well Machs are only 3/4" lower then a gt I believe...so you probably wouldn't see more then a 1/4" in drop...unless you're gonna cut the mach springs first.
Old 08-10-2013, 04:48 PM   #12
I still think best bang for your buck is c springs with tokico's. People have been running this setup for years.
07:36 PM
