Need to connect red wire to gray wire. - Mustang Evolution
Old 08-06-2013, 12:47 PM   #1
clflorida's Avatar
Region: Arkansas
Can I take out the gray wire and solder it that way. Or do I need to make a splice?
Edit: its hot as hell outside. Couldn't think straight. I've other forums that say you need the big brown wire and the instructions say solder the red wire to the big gray one. Do I need the gray or the brown?
clflorida is offline   Reply With Quote
Old 08-06-2013, 01:01 PM   #2
clflorida's Avatar
Region: Arkansas
2002 mustang. Plz guys the heat stroke is real.
Old 08-06-2013, 04:58 PM   #3
sam62893's Avatar
The heat must be intense... I have no idea what your goal is need info on what it is and what you're doing
Old 08-06-2013, 05:11 PM   #4
clflorida's Avatar
Region: Arkansas
Oh well im at work so im not doing it any more for right now. But http://www.americanmuscle.com/99-04-...low-gauge.html
Old 08-06-2013, 06:46 PM   #5
clflorida's Avatar
Region: Arkansas
Oh forgot to say I went ahead and spliced the big brown wire .Then soldered it....I did a rather ****ty job compared to what I had in mind. Never done a splice before so yea. Um ill reply back when it turns dark. I couldn't tell if the dimmer was working. I think I need to ground the black wire, there was a big rusted kinda cylinder behind the guage cluster. I thought it was metal so I just electrical taped the wire to that....idk what else to do on the ways of grounding...
09:48 PM
