86 5.0 in a sn95? - Mustang Evolution
Old 08-06-2013, 04:53 PM   #1
86 5.0 in a sn95?
I found a 86 5.0 and I was wondering if it would bolt up to my 95 3.8 tranny think its a t-5 p.s. new to mustangs
Golden95 is offline   Reply With Quote
Old 08-06-2013, 05:57 PM   #2
sam62893's Avatar
I've heard of those swaps a lot, but I'm not entirely sure it bolts right on to the tranny. I have a 97 V6 tranny out back. If you'd like I'll take a picture for you to compare bolt patterns?
Old 08-06-2013, 06:42 PM   #3
wc3john's Avatar
Check the bell housing but it should.
If at all possible, do NOT get a 86 5.0 but a 87-92.
The 86 5.0 has even worse heads then the dreaded E7.
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 08-07-2013, 12:54 AM   #4
lemons95's Avatar
bell housing is different, the transmission should work.
An even better swap would be a 351, but if the 5.0's cheap enough it can be built to satisfy MOST gear heads.
Old 08-07-2013, 06:20 AM   #5
Thanks for all the input
Old 08-07-2013, 06:53 AM   #6
I probably will go with that 5.0 it is pretty cheap and I can hear it run so that will probably sit on a stand and get built until until I'm somewhat satisfied with it haha
Old 08-07-2013, 11:29 AM   #7
mummert_96v6's Avatar
Just saying if I were you I wouldn't use the 3.8 tranny even if it does bolt up, most likely it's just a t45 like the 3.8 came with. And I've already tore up one of those transmissions with my sixxer and its only got a cai and an 8.8 rear for upgrades
mummert_96v6 is offline   Reply With Quote
Old 08-07-2013, 12:07 PM   #8
351stroker's Avatar
Unless you upsize the valves the turbo swirls will suck.
351stroker is offline   Reply With Quote
08:17 PM
