Steering wheel feels a little loose - Mustang Evolution
Old 08-07-2013, 08:28 PM   #1
1999mustang's Avatar
I have a 1999 v6 I love it but the steering feels a little loose. As in there is a tiny bit of play but the main thing is the steering feels A little to easy to turn ether left or right but only for like 1/4 of a turn...I don't know if this makes sense but if you understand how would I tighten it? Could it be worn tie rod ends or just does the steering wheel Column need to be tightened(Im learning to work on cars I don't know much yet)
1999mustang is offline   Reply With Quote
Old 08-07-2013, 08:36 PM   #2
samuelsmith's Avatar
If you slow down turning the r.p.m.s go down so the power steering does not turn as easily. Could posibily be another problem.
Old 08-07-2013, 10:20 PM   #3
Billymich's Avatar
The stock steering column has terrible coupling bushings, aftermarket columns are about 150 and fix the issue
Old 08-07-2013, 11:33 PM   #4
sam62893's Avatar
+1 look at your steering column and check out the whole thing, might be something loose In there
Old 08-08-2013, 07:04 AM   #5
Thanks I'm gunna check into that
06:40 AM
