My radio - Mustang Evolution
Old 08-09-2013, 07:41 PM   #1
Yzfoxracer's Avatar
My radio
Hey guys my new Pioneer I just put in about a week and it stopped working today. I pulled the radio out checked all the wires and they're all fine I checked the fuse on the back of the radio itself that's fine. Then I put my old radio back in and that doesn't work either now. So Does anyone know what I should do
Yzfoxracer is offline   Reply With Quote
Old 08-09-2013, 07:50 PM   #2
sam62893's Avatar
Could be a fuse in your fuse box?
Old 08-09-2013, 07:54 PM   #3
Yzfoxracer's Avatar
Do you know what one it is?
Old 08-09-2013, 07:57 PM   #4
samuelsmith's Avatar
Wow! The internet is much better at the Holiday Inn in N.C.
Check continuous power, uncontinuous power and ground with a test light. You need to turn the car on to check uncontinuous power
Should be fuse 25 under the hood.
Old 08-09-2013, 08:37 PM   #5
sam62893's Avatar
And if that doesn't work try the fusebox under the steering wheel. I don't know the fuse off the top of my head but google is your best friend. The fuses inside are all 20 amp it's always good to keep spares
Old 08-09-2013, 09:06 PM   #6
Old 08-10-2013, 11:02 AM   #7
Yzfoxracer's Avatar
I got it working guys it was the #32 fuse under the dash
Old 08-10-2013, 01:58 PM   #8
sam62893's Avatar
Nice! Keep some spares just in case. And If it happens again your ground could be bad
05:57 AM
