FYI 96.8" underdrive belt not the best size - Mustang Evolution
Old 11-26-2003, 09:28 AM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Just wanted to let you guys know about this. I got an underdrive pulley about a year and a half ago, and in that time I've gone through 3 serpantine belts. They go fine for a while, then they start squeeling and eventually die. One shreaded itselfand tore up my fire blanket and battery holder, the other just started falling off. I've fixed this on mine and I figured I'd let everybody know about it. Since the belts stretch a little over time, having a belt where the tensioner is all the way out when it's tight, isn't the greatest way to go about it. Currently I'm running a 95.5" belt and it works great. The tensioner is nice and tight and it won't squeel. I also can't just slip the belt out from under the idler pulley anymore like I could with the longer belt. If anyone else is having this problem, try the smaller belt. It's also cheaper than the 96.8" one. the 95.5 was only $15 as opposed ot the $28 for the bigger one.
Wish i would have though of this $70 ago
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 11-26-2003, 09:32 AM   #2
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
I'll have to get one... I need a new belt... mine squeaks on startup
Rellik is offline   Reply With Quote
Old 11-26-2003, 09:47 AM   #3
tire's Avatar
Send a message via AIM to tire
huh, that's funny, what underdrive setup do you have? i have a 25% underdrive on the crank only and am running a 96.6" with no problems, and have for a couple years.
tire is offline   Reply With Quote
Old 11-26-2003, 10:14 AM   #4
I have a feeling that my belt is just OLD.
Old 11-26-2003, 02:00 PM   #5
tire's Avatar
sorry rellik, i was reffering to horse's belt problems. serpentine belts do need replacing, but your car is what, 5-6 years old? i wouldn't think you'd need one already. when you do buy one, i suggest a Gates brand... it should last forever... and it's warrantied forever i think too. the down side is that mine was 30$ i think.
Old 11-26-2003, 02:06 PM   #6
Region: Iowa
I have an ASP 25% underdrive pulley
Old 11-26-2003, 02:21 PM   #7
Thanks for the FYI. ASP's belt guide listed the 96.8" one. I'll have to
start selling 96.5s if this is a common problem although I haven't heard
anyone complain yet...
-Mik
Redlined Performance Mustangs
Cylinder Head / Intake Porting, Camshafts, Pistons, Cold Airs/Pulleys
www.rpm-mustangs.com
http://rpm-mustangs.com/pictures/KEcrank.jpg
mikael is offline   Reply With Quote
Old 11-26-2003, 02:31 PM   #8
tire's Avatar
oh, and for the record i have the exact same pulley (25% ASP) and year car as horse's. 96"-96.5" both work fine from what my friends have said as well.
Old 12-07-2003, 09:39 PM   #9
i've installed a few 96.8" belts and didn't like how they felt, so I sell 96" belts with my UD pulleys.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
smog pump removal.. Belt size? GTOWNR 1979-1995 Mustang GT 9 05-04-2007 06:10 AM
18" wheels, what size tires?? fossen Mustang Wheels & Tires 28 03-28-2007 01:10 PM
What size Tires on 05GT 20" Rims? Ldrett Mustang Wheels & Tires 22 11-28-2006 12:03 AM
UD pulley belt size? Zim Pre-2005 V6 Mustang 8 02-17-2005 11:36 PM
02:34 AM
