Exhuast system - Mustang Evolution
Old 08-10-2013, 08:09 PM   #1
KamzGT's Avatar
Bought a 2001 v6, has true duals. It comes down towards middle as true duals then turns into 6 inches of 1 pipe then back to two pipes. I'm not sure what to call this... Also has dual borla mufflers. It's too quite but sounds like a v8. What is this pipping called and what mufflers should I get to make louder but still sound like 8???
KamzGT is offline   Reply With Quote
Old 08-10-2013, 08:59 PM   #2
Pavimo's Avatar
Maybe it isn't true dual? And you won't be able to make it sound like a V8 unless it's a V8 :/
Pavimo is offline   Reply With Quote
Old 08-10-2013, 09:03 PM   #3
KamzGT's Avatar
It's true duals, I got underneath it when it was on a rack and the set up is GORGEOUS but it's weird. It's a Y then when gets the the middle it's an upside down V. Idk if it's considered x pipe?
Old 08-10-2013, 09:23 PM   #4
mummert_96v6's Avatar
Dow your kit look like this?
http://www.americanmuscle.com/pypes-...t-9604-v6.html
If so it's not true dual exhaust. A true dual will have a Xpipe or an Hpipe
mummert_96v6 is offline   Reply With Quote
Old 08-10-2013, 09:28 PM   #5
KamzGT's Avatar
No, Idk how to explain
Old 08-10-2013, 09:35 PM   #6
KamzGT's Avatar
It's like a x but the point where the two lines meet in the middle, it goes stays on pipe for 6 inches then crosses out again like the rest of the x
Old 08-10-2013, 09:47 PM   #7
If it goes down into 1 pipe then it's not true dual, it's a dual exhaust conversion but not "true" dual exhaust
Old 08-10-2013, 09:51 PM   #8
KamzGT's Avatar
It has two pipes coming from the headers, then 6inch of single which must be the connection to the cat back cuz it then comes back out to one pipe on driver side with borla muffler and one pipe on passenger side with borla muffler.
---------- Post added at 08:51 PM ---------- Previous post was at 08:50 PM ----------
Oh okay I understand now, what r the advantages of having this set up???
Old 08-10-2013, 09:54 PM   #9
Four Eyes's Avatar
Just sounds like a resonator to me.
1986 GT with the typical poor boy mods. 3.73s, Hurst short throw, King Cobra Clutch with aluminum quadrant, lowered two inches on Eibach springs, Hopefully adding some heads and a decent intake soon!
Four Eyes is offline   Reply With Quote
Old 08-10-2013, 09:57 PM   #10
KamzGT's Avatar
That make any difference? I need to figure out if my exhaust is even worth keeping, what mufflers should I put on for a head turner for a great sound? Not a import sound
Old 08-10-2013, 10:05 PM   #11
Ubnbit's Avatar
It gives u a small boost in rwhp. It uses the factory Y pipe to connect to the dual exhaust. If u look, all the kits I see from am are this way.
Old 08-10-2013, 10:05 PM   #12
Ubnbit's Avatar
U should have a much better sound than stock.
Old 08-10-2013, 10:08 PM   #13
KamzGT's Avatar
I sounds good at 2500 to 3k when rev, but it's too quite from the borla mufflers, so I need to get different mufflers to increase sound but also not sounds poppy
Old 08-10-2013, 10:10 PM   #14
Ubnbit's Avatar
Here is what u need bro.
Old 08-10-2013, 10:13 PM   #15
KamzGT's Avatar
Not a fan of h pipes, California laws are crappy, h pipe will fail smog in most place in California. Thanx tho bro, I appreciate your help!
Old 08-10-2013, 10:15 PM   #16
Ubnbit's Avatar
What u probably need is a muffler delete (if its not already done) with a good set of borla axle backs. The borla's shouldn't be quiet.
---------- Post added at 12:15 AM ---------- Previous post was at 12:13 AM ----------
For true duals tho and to separate it from that y pipe, it will have to be h or x. How does h or x affect emissions? Isn't that done based upon ur o2's in the cats?
Old 08-10-2013, 10:16 PM   #17
KamzGT's Avatar
Can't pass smog without mufflers, u can but very rare and hard to legally
Old 08-10-2013, 10:16 PM   #18
Ubnbit's Avatar
Gotta love Cali lol. The muffler part I understand but not the h.
Old 08-10-2013, 10:19 PM   #19
KamzGT's Avatar
The h pipe from what I heard for some reason is too loud for the California decibels and theirs not much back pressure so it allows some emission to get thru, in CA having an older car is hard to own, they set the emissions sooooo low u basically gotta run multiple cats now
---------- Post added at 09:19 PM ---------- Previous post was at 09:18 PM ----------
My ranger has two mufflers now and my mustang has two, that tells me Cali SUCKS
Old 08-10-2013, 10:19 PM   #20
Ubnbit's Avatar
Dang. Then it sounds like the only way to change the sound would be to change the whole setup, keeping the factory Y.
Old 08-10-2013, 10:20 PM   #21
KamzGT's Avatar
Fasho! What's your opinion on me putting two slp loud mouths on to replace the borla mufflers?
Old 08-11-2013, 06:28 AM   #22
Ubnbit's Avatar
The SLP loudmouths u have are a muffler delete.
Old 08-11-2013, 08:25 AM   #23
sam62893's Avatar
Pics of your setup?
Just find a place and ask about the "special" smog. My whole intake and exhaust is illegal in Cali but I get around that. I have a friend whose uncle owns a smog place. Pay $150 for my smog but I pass.
Modified intake, BBK shorties, pypes xpipe, hi-flo cats, pypes mufflers. Sounds mean but I still want louder. And the whole setup is illegal in soviet California
01:53 PM
