cam setup - Mustang Evolution
Old 08-12-2013, 10:31 PM   #1
ProjectTurboV6's Avatar
cam setup
I'm looking at a couple different setups right now, but for my n/a project I'm thinking of getting a 224/230 .55-.55, 114lsa, with 1.7 rockers. Will that give me the quick acceleration I'm looking for??
ProjectTurboV6 is offline   Reply With Quote
Old 08-12-2013, 11:12 PM   #2
davidcseifert's Avatar
Region: Arkansas
I forget are you still single port? also what is your trans setup?
That's more of a higher end cam than low end. But other factors play into more than just can specs. List everything you have done or will be done with cam please
blower/new cam soon
Old 08-12-2013, 11:32 PM   #3
My n/a setup is a 1998 4.2 block pistons cam, 2003 splitport heads and windstar intake (2000 lower), e150 fuel rail, #36lb injectors, 255lph pump,bigger valves, longer rods, stronger springs, 65mm tb, cai.
Trans setup is just the stock t5
Old 08-12-2013, 11:51 PM   #4
Region: Arkansas
Stock heads with bigger valves cut in or ported too? Ported lower or stock?
224/230 little on the big side for stock ports if so.
Also I can set you with a cam for cheaper than the ssm cam you posted if you wish, just send me a pm.
blower/new cam soon
Old 08-12-2013, 11:55 PM   #5
samuelsmith's Avatar
My favorite post. I am getting a cam also. Listen to David he will not steer you wrong.
Old 08-12-2013, 11:55 PM   #6
4angle valve job and stage 2 porting on heads and lower intake. Would the chemistry of that setup run smoothly in your opinion?
Old 08-13-2013, 12:07 AM   #7
Region: Arkansas
Ah I like to hear that it's ported some lol
It should work alright, if you're not geared I would recommend getting 3.73's or so. Like I said the bottom end is kinda sluggish with bigger cam.
Maybe would tighten up the lsa if its going to stay an N/A, a 112 or so.
blower/new cam soon
Old 08-13-2013, 12:17 AM   #8
Yeah I'm going the 8.8, 3.90 route after my next pay check. I think I'd do a 110 lsa so I can get more torque and hit the power band earlier
Old 08-13-2013, 12:24 AM   #9
Region: Arkansas
Nice, should feel real good with those gears.
blower/new cam soon
04:01 AM
