How can i run bigger tires in the rear - Mustang Evolution
Old 08-13-2013, 03:15 PM   #1
greenstang41's Avatar
O I need wider rims I want 285 or larger
greenstang41 is offline   Reply With Quote
Old 08-13-2013, 03:17 PM   #2
JimmyMosqueda's Avatar
Roll your fenders? A member here runs 315s. He'd be able to tell you what to do.
JimmyMosqueda is offline   Reply With Quote
Old 08-13-2013, 03:42 PM   #3
Pavimo's Avatar
Buy the tires you want and see if it rubs. If it does, roll fenders. If it doesn't, then it doesnt!
Pavimo is offline   Reply With Quote
Old 08-13-2013, 03:45 PM   #4
1slosix's Avatar
first off what rear wheels do you have? that's what we need to know above anything else.
carving corners like a boss
Old 08-13-2013, 03:47 PM   #5
1lowGT's Avatar
There's a kit if people running wider than 315s not stock though. If you're lowered you may need to roll the fenders. Depends in the size. If your 17s then you could do a 315/45or40/17 if you're 18s then I wouldn't go any taller than a 315/35/18
---------- Post added at 04:47 PM ---------- Previous post was at 04:47 PM ----------
+1 that'll help
Old 08-13-2013, 06:23 PM   #6
245/45 17 in rims
Old 08-13-2013, 06:23 PM   #7
Old 08-13-2013, 06:25 PM   #8
Venomouz831's Avatar
Need at least a 10' wide rim. Ran 315-40-18 before and also a 305-45-18. You will rub if lowered 1.5 or more.
)02 Gt, Founder of WE2G
Old 08-13-2013, 10:14 PM   #9
Pavimo's Avatar
Front tire looks really warped because of the lighting >.<
Old 08-13-2013, 10:16 PM   #10
1slosix's Avatar
run a 275 on the rear...that's what i ran when i had cobra R's
Old 08-14-2013, 06:12 AM   #11
Doe_Rae_mi's Avatar
I'm running 315's in the back and I definetly need to roll my fenders
02:56 AM
