T5 for 3.8 - Mustang Evolution
Old 08-15-2013, 07:46 PM   #1
mummert_96v6's Avatar
T5 for 3.8
Does anybody know if the t5 from a foxbody with a 5.0 will work behind a 3.8? My car is a 96 and has the t45 and the second gear synchro is bad so it grinds going into gear almost every time. I can find t5s from the foxes all over the place and was wondering if it will fit behind the 3.8
mummert_96v6 is offline   Reply With Quote
Old 08-15-2013, 08:58 PM   #2
Dpred03's Avatar
I pretty sure you can make it fit you'll probably just need a different bell housing and maybe some other misc parts
Dpred03 is offline   Reply With Quote
Old 08-15-2013, 09:45 PM   #3
I was told somewhere that something's different but I can't remember what it was idk if it was the bell housing or the input shaft length or something
Old 08-15-2013, 09:58 PM   #4
Dpred03's Avatar
I think that the fox uses a world class t5,and so does the 99-04 which is built off the same frame as the 94-98. I think with a different bell housing and maybe a different drive shaft you should be able to make it fit no problem. Maybe someone with some more knowledge will tell you exactly for sure though.
Old 08-16-2013, 12:22 AM   #5
davidcseifert's Avatar
Region: Arkansas
Same bell housing, both small block ford pattern.. Pretty sure it's The input shaft that is the wrong length to go between the two
blower/new cam soon
Old 08-16-2013, 08:55 AM   #6
BloodRedStang's Avatar
Fox input shafts are 3/4" shorter as are the bellhousings to accommodate the shorter distance from back of block to shifter location.
You can use a fox trans with the fox bell, it will put your shifter a little closer to the dash in sn95 cars but if you have a steeda tri-ax or another short throw similar to that you won't even realize it. Even with the stock shifter, a day or two and you won't realize it. But you have to make sure if you use a fox trans that you use a fox bell, and if you use a sn95 trans, you have to use an sn95 bell. Otherwise the inputshaft will be either too short or too long to engage properly.
---------- Post added at 10:55 AM ---------- Previous post was at 10:54 AM ----------
Oh, and if you use the fox trans/bell, you will have to trim a little metal away from the front of your shifter hole, not much at all, but once you start putting the trans in and test fitting everything you'll see what I'm talking about.
BloodRedStang is offline   Reply With Quote
Old 08-16-2013, 01:13 PM   #7
Ha I don't think it's gonna work then with a fox trans because I have a hurst short throw shifter and when I'm in 1st the shifters already pretty close to the dash. Could I take the input shaft and bell from my t45 and put them in a fox t5 because I know the two transmissions are pretty similar
Old 08-16-2013, 02:00 PM   #8
I don't know there man, I'm not familiar enough with the t45s. Look for scottydsntknow on here, he knows a good deal about transmissions. The only trans I'm familiar with is t5's.
Old 08-16-2013, 08:54 PM   #9
Well thanks anyways I hope somebody on here who knows chimes in
Old 08-16-2013, 09:37 PM   #10
No problem man.
if I remember correct the t45 wont bolt to a t5 bell, and the the t45 bell won't work with a small block.
and I think the output shafts are different, like not even interchangeable.
Old 08-16-2013, 09:48 PM   #11
2300turboford's Avatar
A 4cyl tranny will work
Old 08-17-2013, 06:28 PM   #12
That still is the fox trans that's 3/4 of an inch shorter and I can't use that
Old 08-17-2013, 08:24 PM   #13
exactly. your best bet is craigslist or picknpull/upullit places like that.. around here I can pick up 6cyl t5s for 75-150 all day long. no one does their research and looks down on the 6cyl t5s. this winter when I swap the aode out of my gt I'm planning on putting a 4-6cyl t5 in because I know I'm gonna bash on it with a new engine...why pay the extra 2-300 people want for a v8 trans when all t5s are inherently weak and going to fall apart at some point anyhow lol
Old 08-18-2013, 10:46 AM   #14
The v6 trans from 94-04 wasn't a t5 it was the t45 which was a downgraded version of the t5 used for the v6. In the foxbodys the 4cyl used a t5 but it was downgraded just like the t45 for the v6. If you get a t5 from a 94-95 5.0 you'll be fine those from what I was told was the strongest t5 from factory
Old 08-18-2013, 11:51 AM   #15
Dpred03's Avatar
I'm pretty sure that the 99-04 v6 used a t5 the 94-98 might be different
Old 08-18-2013, 12:10 PM   #16
95 was the last year they put the t5 in from factory. All 94-04 v6 used a t45. I think in 99-04 the gt trans changed to either a t3650 or a t56 or something like that
Old 08-18-2013, 02:11 PM   #17
94-95 v6 and v8 had t5s, they changed to the t45 in 1996 when they switched to the modular 4.6 v8.
---------- Post added at 04:11 PM ---------- Previous post was at 04:09 PM ----------
they had t45s from 96 up til 05 I think. t56 is a 6 speed.
I assure you, 94 and 95 were t5's
Old 08-18-2013, 03:49 PM   #18
01-04 GTs used the t3650 5speed transmission
Old 08-18-2013, 05:40 PM   #19
just looked it up again.
94-95 was t5 v6/gt/cobra
96-01 was t45 on gt/cobra
94-04 v6 still had the t5
01-10 was tr3650 on the 01 cobra/01-up gt
95 cobra R had tr3550
and at some point they used the t56, I believe those were in terminators.
Old 08-18-2013, 08:18 PM   #20
Dpred03's Avatar
T56 is definitely the 03-04 terminators only
Old 08-18-2013, 08:30 PM   #21
That's what I thought, I've never seen another sn or NE that had a 6 speed. I've seen a termi in person 1 time.. lol
Old 08-18-2013, 09:25 PM   #22
94-04 v6 didn't use the t5 they used t45 that's what's in my 96 six banger from factory
Old 08-18-2013, 10:28 PM   #23
Then it wasn't factory.
I promise you, they were t5.
4 cyl 5 speeds in the foxes? T5s.
V8 5 speeds in the foxes up to 95? T5s.
6cyl 5 speeds from 94-at least 99? T5s.
I'm not going to argue this fact anymore. Ill provide links to info pages if you'd like.
Old 08-19-2013, 01:06 AM   #24
Region: Arkansas
All the sn V6's are T5's...
blower/new cam soon
08:54 AM
