New EBC rotors and pads - Mustang Evolution
Old 08-16-2013, 09:22 AM   #1
Just received my new EBC Sport rotors and red stuff pads.
Beautiful day out for a little driveway wrenching. More pics to follow.
delff128 is offline   Reply With Quote
Old 08-16-2013, 09:38 AM   #2
610swolf's Avatar
nice how much did those run you. I may be in the market for new rotors soon.
610swolf is offline   Reply With Quote
Old 08-16-2013, 10:02 AM   #3
The front set was $163 and change and the rear set was $140 and change from AutoAnything after 15% off, free shipping, and no tax. Obviously your price may vary based on your model and year, but I felt like I got a great deal especially given EBC's reputation and quality products.
Old 08-16-2013, 01:39 PM   #4
1slosix's Avatar
Good products but be careful running both slotted and drilled rotors on a DD.
carving corners like a boss
Old 08-16-2013, 01:41 PM   #5
Thanks. However, they are dimpled and not drilled so I'm not too worried about the potential problems associated with drilled rotors.
Old 08-16-2013, 08:21 PM   #6
Fourloko530's Avatar
What could happen with a dd and those rotors
Fourloko530 is offline   Reply With Quote
Old 08-16-2013, 09:48 PM   #7
andregayola's Avatar
Yea i agree
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 08-16-2013, 09:57 PM   #8
Dpred03's Avatar
Not to thread jack but what's the issue with both slotted and drilled?
Dpred03 is offline   Reply With Quote
Old 08-16-2013, 10:18 PM   #9
Someonee answer lol
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 08-17-2013, 12:50 PM   #10
Blovett55's Avatar
Warping I believe or cracks, drilling into the rotors compromises the integrity of the rotor
With that said I still plan on getting some drilled and slotted rotors
Blovett55 is offline   Reply With Quote
Old 08-17-2013, 01:53 PM   #11
Dpred03's Avatar
So basically drilling into the rotors is the dangerous part? Is there any evidence of this? And just out of curiosity, how hot do rotors typically get during moderate use?
Old 08-17-2013, 01:57 PM   #12
Drilled rotors have a tendency to crack between the drill holes. I recommend dimpled/slotted for the look without the risk.
Old 08-17-2013, 04:19 PM   #13
sam62893's Avatar
Yeah my drilled rotors are slightly cracked. You can barely see them. Then again it's an autozone brand (came with the car) they still stop better than my stock rotors but its a little squeak that drives me crazy. Someone recommended brakemotive. Said its a good brand and uses it for DD and track use. Holding up good
Old 08-17-2013, 05:19 PM   #14
1slosix's Avatar
This...
Old 08-17-2013, 08:49 PM   #15
Blovett55's Avatar
I've heard theyr good too, and fairly cheap too
Iv seen couple videos were they did alot of heavy braking on a machine with the rotor basically continuously making the brake glow red then used a dial indicator(metrology tool) after it cooled and measured the vibration(warping) and it was like only 1/100th of an inch which is in spec
Old 08-18-2013, 07:48 AM   #16
Rotorpro is where I got mine. Between autox, drag strip and heavy street use I have had no issues. Going on 4 years with the rotorpro dimpled/slotted and hawk hps+ pads.
Old 08-21-2013, 11:46 AM   #17
New caliper, new pads, and new rotor done!
Old 09-02-2013, 09:26 PM   #18
100 miles on the new brakes so far and wow talk about night and day difference. The initial bite is substantial and I probably look like a 16 year old just learning to drive as I leech along when I hit the brakes since I'm still adjusting to the new sensitivity lol.
Old 09-02-2013, 09:59 PM   #19
1slosix's Avatar
i see you're still running rubber brake lines...you think they feel great now. swap over to braided lines and you'll never go back to rubber .
Old 09-03-2013, 05:04 AM   #20
2000stanguy's Avatar
How do SS brake lines help?
Performance Red 2000 v6- m112 supercharger,42lb green top injectors, 310lph fuel pump, BBK shorty headers, True dual exhaust, strut tower brace, GT rear sway bar, Steeda triax short throw shifter, SR lowering springs, tinted headlights and foglights, polk audio speakers, MTX subwoofer, Kenwood head unit and black leather interior.
2000stanguy is offline   Reply With Quote
Old 09-03-2013, 06:54 AM   #21
1slosix's Avatar
no expansion of the line even under heavy braking which would normally give your breaks that spongy feeling. also will help the breaking distance a bit.
Old 09-03-2013, 03:41 PM   #22
Ok thanks!
08:55 PM
