Turn downs - Mustang Evolution
Old 08-16-2013, 04:25 PM   #1
bkh1994's Avatar
Turn downs
I have read that turn downs for dumped exhaust will cause less vibrations, less interior drone, and louder outside of the car; is this true? Also, where is somewhere I can find them cheap because $25+ is too much just for some turn downs. OR is there an alternative or something cheap I could use instead?
bkh1994 is offline   Reply With Quote
Old 08-16-2013, 04:31 PM   #2
1lowGT's Avatar
You can cut all the piping off behind your muffler and put some 90 degree turn down tips. I dumped my flows and it was really droney really bad in low rpms. And not as loud. I also dumped my slp and they weren't as loud and it was with full piping.
Old 08-16-2013, 04:32 PM   #3
Doe_Rae_mi's Avatar
Complete opposite actually. Louder inside. Quiter outside. Plus if u are on dirt, dirt will fly everywhere
Old 08-16-2013, 04:42 PM   #4
1lowGT's Avatar
+1 inside drones bad.
Old 08-16-2013, 04:43 PM   #5
bkh1994's Avatar
Haha I must've read it wrong. What if they are angled to the outside edge some?
Old 08-16-2013, 04:51 PM   #6
Doe_Rae_mi's Avatar
it will still drone. Since the exhaust is leaving right below you.Honostly IMO I think the only cars that should run dumps are the old muscle cars. I've had it on my 2v and the inside noise is silly compared to the outside. It's mad loud inside and not loud at all on the outside*
Old 08-16-2013, 04:51 PM   #7
1lowGT's Avatar
You'll want it angled down as much as possible. It's not a bad idea lots of people do it.
Do it like this. Lots of drag cars do it but they aren't anywhere buy a drag strip
Old 08-16-2013, 07:15 PM   #8
bkh1994's Avatar
Any cheap ways or alternatives to get that done? 25 for a pair is too much imo
Old 08-17-2013, 12:01 AM   #9
1slosix's Avatar
Attachment 124156
i see my old car's exhaust pic is still coming in handy
you can buy turndowns at Advance for like $7 a piece and they are bolt on...i'd reccomend either welding or using good clamps instead. so you're still looking at $20 for two turn downs with clamps....however the exhaust shop i go to only charges $5 a tip to make a turn down since it's just a bent piece of exhaust tubing cut at an angle.
carving corners like a boss
Old 08-17-2013, 06:23 AM   #10
bkh1994's Avatar
I'll be getting them welded on. Thanks for the help!
Old 08-17-2013, 07:20 AM   #11
1lowGT's Avatar
Definitely get it welded on there.
---------- Post added at 08:20 AM ---------- Previous post was at 08:20 AM ----------
Might have them weld some hangers at the end too don't want them sagging
Old 08-17-2013, 08:23 AM   #12
bkh1994's Avatar
Where can I get some hangers at? I have a friend doing it, so he won't have any on hand
Old 08-17-2013, 09:10 AM   #13
1lowGT's Avatar
Just use some metal rod
Old 08-17-2013, 10:22 AM   #14
bkh1994's Avatar
Okay cool
Old 08-17-2013, 10:14 PM   #15
1slosix's Avatar
i wouldn't use a solid rod...too much vibration issues at least from what i've used...go to any autoparts store and buy a universal hanger for like $3. they have a rubber piece in there that helps reduce vibration.
Old 08-18-2013, 07:13 AM   #16
Dumps will cause drinks to white cap. It will also make your car the dirtiest vehicle in a gravel parking lot
Old 08-18-2013, 08:35 AM   #17
1lowGT's Avatar
I would stick with a full exhaust set up, it's louder and you don't have to worry about dirty flying up under your car.
Old 08-18-2013, 10:02 AM   #18
bkh1994's Avatar
I want to hear it more in the car and plus my friend is doing it for free, he doesn't have a machine to run it out the back or anything. I'll run dumps till I get tired of it then go pay to get it ran.
Old 08-18-2013, 10:47 AM   #19
1lowGT's Avatar
Alright well i hope you like it!
Old 08-18-2013, 10:49 AM   #20
Doe_Rae_mi's Avatar
Prepare for headaches! What kind of mufflers u runnin?
Old 08-18-2013, 10:50 AM   #21
bkh1994's Avatar
Oval magnaflow mufflers
Old 08-18-2013, 10:52 AM   #22
1lowGT's Avatar
I dumped my flowmaster and it was alright i guess i liked the full catback better, it was louder inside but annoying at low rpms and when you got into fifth gear omg it was sooooo annoying i had them dumped until i got my slp but that was like only for a few days
Old 08-18-2013, 10:59 AM   #23
bkh1994's Avatar
I'm mostly highway so low rpm moments will be few haha
Old 08-18-2013, 11:02 AM   #24
1lowGT's Avatar
If you got long drives its gonna get annoying
Old 08-18-2013, 11:05 AM   #25
bkh1994's Avatar
I never have more than 30 minutes trips. When I go on vacation a bigger car is took so I think I'm set until I get tired of it
Old 08-18-2013, 11:14 AM   #26
1lowGT's Avatar
Post a video when you're done with it.
Old 08-18-2013, 11:17 AM   #27
bkh1994's Avatar
I'll be sure to!
08:26 PM
