HELP!!! Bought new springs - Mustang Evolution
Old 08-18-2013, 09:09 PM   #1
Joey2000srs's Avatar
Just ordered Eibach Sport-Line springs from Tire Rack because i had a gift certificate. Also ordered J&M's 4-bolt camber plates.
Kinda skeptical if my tires will rub once installed?? I currently have 225/60/15 tires on the car. The estimated drop is 1.7" in the front & 1.5" in the rear. The shocks i have installed are KYB gas adjust (very stiff). The new shocks actually picked up the rear end of the car slightly. Will the lowering springs even make a noticeable difference in the back?(Note that the shocks are stiff.)
***Mainly concerned if the tires will rub or not***
My dad told me not to order them because it will make the ride too harsh, i ordered them anyway
Joey2000srs is offline   Reply With Quote
Old 08-18-2013, 09:36 PM   #2
bigmac3's Avatar
If your shocks have no spring on them, they will not alter your ride height.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 08-18-2013, 10:27 PM   #3
1slosix's Avatar
unless he has maybe some dead coils on the back, and the new shocks helped them i dunno just giving OP benefit of the doubt lol.
@OP you'll be fine from the sounds of it...you can always run Isolators off of your old springs to lift the eibachs a 1/4" if you're worried.
carving corners like a boss
Old 08-19-2013, 06:33 AM   #4
I ordered SR Performance isolators, they are thinner than stock?
---------- Post added at 06:33 AM ---------- Previous post was at 06:29 AM ----------
Well, the original shocks had 120k miles on them. So i'm assuming that they were blown & the weight of the car had lowered the car slightly. Probably when i installed the new shocks, it restored it to factory ride height (which i have never seen before.)
Old 08-19-2013, 07:10 AM   #5
Doe_Rae_mi's Avatar
I'm running eibach sportlines and I rub in the back. No rubbing in the front though
Old 08-19-2013, 09:19 AM   #6
What size tires? What's the outside diameter if you don't mind me asking?
Old 08-19-2013, 12:44 PM   #7
Doe_Rae_mi's Avatar
My fronts are 225/45/17 rear is 245/35/17
04:11 PM
