P1336 - Mustang Evolution
Old 08-20-2013, 04:58 PM   #1
RaysV6's Avatar
Send a message via Yahoo to RaysV6
P1336
I just replaced the sensor and the synchronizer, had a shop tdc the motor for me. Now the engine light came back on and throwing the same code. I was told after the sensor was tdc'd and properly aligned it would fix the light. So why am i still getting the code? My exhaust is ****ed!! Could this be another reason why im throwing the code?
RaysV6 is offline   Reply With Quote
Old 08-21-2013, 03:08 AM   #2
davidcseifert's Avatar
Region: Arkansas
Just an FYI there are two tdc points, you have to do it on the compression stroke.
As for the light, does the car run rough at all?
blower/new cam soon
Old 08-21-2013, 03:15 AM   #3
RaysV6's Avatar
It feels like some back pressure issues!! Hesitiant on acceleration!! But i also have a bad cat and bad headers at the flange to the second cat both sides. Im gunna replace the crankshaft position sensor soon, hopefully that will help. Since i replaced the cam shaft and synchronizer i might as well.
Old 08-28-2013, 10:02 PM   #4
RaysV6's Avatar
Well i replaced the cps, and i tell u what, even with the back pressure im having i drove from here(ohio) to nc on two tanks of gas, 300+ each fill up. I had some amazing gas mileage.
02:29 AM
