X-pipe - Mustang Evolution
Old 08-22-2013, 01:26 AM   #1
PiojoA7x's Avatar
Is it possible to make an X-pipe out of scratch. I have a pipe bender and I was thinking of making my own X-pipe. Will this be possible and will it sound good?
PiojoA7x is offline   Reply With Quote
Old 08-22-2013, 06:36 AM   #2
sam62893's Avatar
Can you weld?
Old 08-22-2013, 08:10 AM   #3
Doe_Rae_mi's Avatar
Pipes are pipes it'll sound almost like every other x. But u would be better off buying one
Old 08-22-2013, 10:17 AM   #4
PiojoA7x's Avatar
Originally Posted by sam62893 View Post
Can you weld?
Im no expert but I weld my cats back on when its time for smog check.
Old 08-22-2013, 12:47 PM   #5
sam62893's Avatar
Then yeah. Just bend them the way an x-pipe would look like and cut and weld
Old 08-22-2013, 12:50 PM   #6
Doe_Rae_mi's Avatar
U may be able to make it look like an x pipe but u will need to make it function like an x pipe as well
Old 08-22-2013, 12:52 PM   #7
sam62893's Avatar
Yeah, try and look for schematics of the way x-pipes are formed. I was thinking bend two pipes. Cut both corners and weld together like that. There may more to that equation though
Old 08-22-2013, 02:54 PM   #8
samuelsmith's Avatar
If you can bend you can cut and weld. Just take you time and bend a little at the time till you get it perfect
Old 08-24-2013, 12:29 PM   #9
PiojoA7x's Avatar
I'll give it a shot. If not ill just buy it. Thanxx for the comments
Old 08-24-2013, 12:45 PM   #10
I'm sorry, I don't think any of us know the right angles and lengths to bend at. I'm sure you got eagle eyes
01:23 PM
