Engine mounts location - Mustang Evolution
Old 08-22-2013, 01:35 PM   #1
SpeedyG's Avatar
Does anyone know where the engine mounts are? And the tranny mounts?? Im thinking hear might be causing my engine to shake when shifter out of 1 & 2 gear. 2000 v6 manual
SpeedyG is offline   Reply With Quote
Old 08-22-2013, 03:01 PM   #2
samuelsmith's Avatar
Hit the gas and if the engine does not shake the engine motor mounts are good. BTW the engine mounts are next to the frame and K member
Old 08-22-2013, 03:46 PM   #3
SpeedyG's Avatar
It dies shake alittle, and shifter handle shakes alot
Old 08-22-2013, 06:59 PM   #4
Now you need to figure out if it is driver or pass. side. You need a engine hoist to change the mount. Unless any one knows a easier way.
Old 08-22-2013, 09:50 PM   #5
sam62893's Avatar
Jacking up the engine with a jack and a block of wood one side at a time though
Old 08-23-2013, 11:41 AM   #6
SpeedyG's Avatar
Any idea on the tranny mounts?
Old 08-23-2013, 12:04 PM   #7
It's about 2/3s the way down the transmission. Same basic concept. Jack up the transmission disconnect the cross member and bolts holding it together.
Old 08-23-2013, 12:19 PM   #8
SpeedyG's Avatar
Old 04-08-2014, 08:05 AM   #9
SpeedyG's Avatar
I'm sorry I'm just getting a chance to replace my mounts now. Where/what is the K member? Is the mount on the frame?
Old 04-08-2014, 05:46 PM   #10
This is a k-member. Look at the first bar you see. The metal connected to it is where the mounts are. The metal with the long hole.
You can also just look for the oil pan. look up a little on your left and right towards the front of the engine.
ID:	153282   Click image for larger version
10:03 PM
