Oil leak - Mustang Evolution
Old 08-24-2013, 10:03 AM   #1
813floridaracin's Avatar
Oil leak
Guess who has a serious oil leak..that's right, me. On top of my transmission fluid leak I now have a major oil leak problem.
I change the oil myself every time every 3k miles.
Car takes 5 quarts, and only one..that's right only one quart came out. So four quarts of oil disappeared in two months.
813floridaracin is offline   Reply With Quote
Old 08-24-2013, 10:04 AM   #2
Mustang 2000 v6 auto
Old 08-24-2013, 10:14 AM   #3
sam62893's Avatar
Leaks suck
Old 08-24-2013, 10:57 AM   #4
Fader's Avatar
Region: Idaho
Did you notice leaks in your driveway or garage? Where is it leaking from? If it's leaking, you'd have to be able to find it.
When you change the oil, and replace the filter, are you rubbing a little oil on the filter gasket? Is your car burning the oi?
Fader is offline   Reply With Quote
Old 08-24-2013, 11:49 AM   #5
There's leaks on the driveway, I thought it was only the transmission fluid & I've been topping it off every now and then. But didn't realize it was engine oil because its not leaking from either the oil pan or the filter. And yes I also rub some oil onto the filter gasket. Car doesn't seem to be burning oil because there's no smell or smoke
Old 08-24-2013, 11:54 AM   #6
Fader's Avatar
Region: Idaho
OK, is there oil leaking from around your cylinder heads or valve covers? Done any work in those areas lately? Worst case scenario is a cracked block, but could just be a leaky gasket. Still a lot of work to fix.
Old 08-24-2013, 11:59 AM   #7
Initial inspection there didn't appear to be any oil leaking visibly around the engine. I had the car on ramps and couldn't see anything. I did some work months ago on two power steering hoses that hit each other and cracked.but I never loosened anything that would leak engine oil
Old 08-24-2013, 12:01 PM   #8
All that came out of the engine
Old 08-25-2013, 05:53 PM   #9
lemons95's Avatar
if it's coming out near the transmission it might be the rear main seal.
Old 08-25-2013, 07:42 PM   #10
I actually had a buddy of mine say the exact same thing today. He said I should sell it quick if it really is the rear main seal. Is it a hard fix?
Old 08-25-2013, 08:38 PM   #11
lemons95's Avatar
You have to take the engine out, I don't think its expensive just time consuming. Unless you have a shop do it. Then it will probably get expensive. The rear main seal itself I think is $20-30.
Old 08-25-2013, 08:41 PM   #12
sam62893's Avatar
You just need to drop the transmission. You don't have to take out the whole engine
10:05 AM
