Problem with throttle cable - Mustang Evolution
Old 08-25-2013, 08:43 AM   #1
Crowned1's Avatar
Yesterday I was on the highway and I got on it a little bit to pass someone and I felt a weird snap and the gas pedal seemed to fall even further in than it was before without the throttle cable mod. I checked it out and I don't know what it's missing the cable is still hooked up and everything looks right except the pedal is sitting way below where it normally used to be. Any thoughts? also the spacer did break off when I got on it.
Crowned1 is offline   Reply With Quote
Old 08-25-2013, 09:32 AM   #2
1slosix's Avatar
well the slack could be the spacer missing...did you use a real nylon spacer or something else (using the right spacer wouldn't cause a snap). worse case your cable has stretched. replace the spacer and see if that fixes the slack.
carving corners like a boss
Old 08-25-2013, 09:35 AM   #3
Crowned1's Avatar
I used a nylon spacer yes. I'll go get another one today and put it on real quick and let you know. that thing is such a pain to cut through ha
Old 08-25-2013, 09:41 AM   #4
1slosix's Avatar
wow that's weird...let us know how things go
Old 08-30-2013, 04:35 PM   #5
Crowned1's Avatar
problem fixed by simply redoing the pedal mod! everything's working fine!
09:47 PM
