99 coupe won't start - Mustang Evolution
Old 08-27-2013, 11:24 AM   #1
Region: Arkansas
hi, my 99 coupe won't start. when i turn key it clicks once then nothing. the instrument panel lights up. it is not the battery, and its not the starter. there are no fuses blown, and it's not the relays. what else can i check. im not the best at working on cars so forgive my ignorance. i had the starter checked, i switched out the starter relay with the hi lo wiper relay, which has the same numbers on it, and that doesn't seem to be it either. it doesn't try to start or anything, it just clicks once and that is it. any help would be appreciated.
mike357 is offline   Reply With Quote
Old 08-27-2013, 11:30 AM   #2
1slosix's Avatar
could still be the starter....the solenoid is clicking but the bendix may not be kicking out
carving corners like a boss
Old 08-27-2013, 12:34 PM   #3
sam62893's Avatar
Yeah, starter should keep on clicking for a while. I had a 97 with no engine and the wiring harness in battery an everything. Put the key all the way to start and all that is heard is one click. Now with the starter if the battery is dead the starter will keep on clicking and if the starter is dead you won't hear the ticking
Old 08-27-2013, 04:00 PM   #4
Region: Arkansas
so even if i took it to oreilys and had the starter checked, it could still be that? they said it should be testing the solenoid too. i tend to believe you guys more than the guy up there, he didnt really seem to know.. so it could still be the starter/solenoid??? thanks for helping.
Old 08-27-2013, 05:06 PM   #5
lemons95's Avatar
had this problem with a ford ranger in the autoshop, a dead battery with some juice would make the clicking noise though.
But if it's not the battery it's starter. I don't know how much they cost because, when I replaced the one on the ranger the school paid for it.
Old 08-27-2013, 05:57 PM   #6
1slosix's Avatar
did they put it on the machine in the store (like with it off the car) or did they just use a handheld tester. Working at Advance I will say handheld testers aren't very accurate for the starter testing..Best way is to pull it off and have it put on the bigger machine in the store. or even just take a stick and mallet...start tapping the side of the starter with some force while someone tries to start it...
Old 08-27-2013, 06:02 PM   #7
Liebert91stang's Avatar
I had that happen few times and it was my ground wire not making good connection for battery post.may check it
Liebert91stang is offline   Reply With Quote
Old 08-27-2013, 06:10 PM   #8
lemons95's Avatar
we bench tested the starter in autoshop, I was sick that day though...
I'm sure you could find a video on youtube, and bench test it.
Old 08-27-2013, 07:21 PM   #9
03GT88's Avatar
Pretty sure it's the starter
03GT88 is offline   Reply With Quote
Old 08-27-2013, 08:08 PM   #10
Region: Arkansas
i took it off and they tested it on the bigger machine in the store
Old 08-27-2013, 08:16 PM   #11
sam62893's Avatar
Try another store. You can never get a very accurate reading with someone who doesn't know how to work the machine. Believe me. I took an alternator to 3 auto zones one day. The first one said its toast and the other two said it was fine
Old 08-27-2013, 08:29 PM   #12
Region: Arkansas
i'll do that
Old 08-27-2013, 10:40 PM   #13
03GT88's Avatar
Did you see the starter gear rise up and spin when tested?
Old 09-06-2013, 12:01 PM   #14
Region: Arkansas
thank you guys for the help. it was the starter. oreilys was wrong. got it running now. i really appreciate your help. now i know to not trust their testers
02:39 PM
