99 mustang 5 speed - Mustang Evolution
Old 08-27-2013, 08:58 PM   #1
5speedChris's Avatar
My 99 mustang will start and run for about 5 miles until the engine heats up then It starts to idle really low and shortly after that it will die and won't start up until I let it sit for a few hours. I need advice on what might be the problem.
5speedChris is offline   Reply With Quote
Old 08-27-2013, 09:16 PM   #2
Venomouz831's Avatar
How's the temp on it? You got any coolant in there?
)02 Gt, Founder of WE2G
Old 08-27-2013, 09:44 PM   #3
The temp is fine but once the engine gets heated up to Normal temp is when it idles at about 300 then you try to take off and hit the gas and the car just dies. Then it will not start until you wait for it to cool down. And yes the coolant and radiator are filled.
Old 08-27-2013, 09:55 PM   #4
It could be a number of things. But I'm thinking it could be my iac.
Old 08-27-2013, 10:17 PM   #5
TheBandit's Avatar
Sounds like a clogged fuel filter to me. Have you Changed it yet?
TheBandit is offline   Reply With Quote
Old 08-27-2013, 10:46 PM   #6
No. can I clean it to unclog it or should I just buy a new one?
Old 08-27-2013, 11:47 PM   #7
lemons95's Avatar
there only like $8, $12 for the more expensive ones.
Old 08-27-2013, 11:54 PM   #8
sam62893's Avatar
Autozone. $5
Old 08-28-2013, 12:15 AM   #9
Good stuff ill have to let you know how that turns out.
Old 08-28-2013, 09:34 AM   #10
sebasflorez's Avatar
Make sure you get the removal tool. Looks like this:
http://www.amazon.com/gp/aw/d/B0002S...AC_SX110_SY165
sebasflorez is offline   Reply With Quote
Old 08-28-2013, 09:51 AM   #11
samuelsmith's Avatar
I would take it down 2 the zone and run codes
Old 08-28-2013, 11:38 AM   #12
Run codes?
Old 08-28-2013, 11:49 AM   #13
JimmyMosqueda's Avatar
You can take your car to any AutoZone and they will read the codes, if any are given, from a check engine light.
JimmyMosqueda is offline   Reply With Quote
Old 09-01-2013, 06:32 PM   #14
It's done for. Going back to the 5.0
Old 09-02-2013, 12:13 AM   #15
351stroker's Avatar
Wha?? Cooked engine?
351stroker is offline   Reply With Quote
Old 09-02-2013, 12:38 PM   #16
Yep. Haha
Old 09-03-2013, 08:56 AM   #17
351stroker's Avatar
*****ty.
---------- Post added at 08:56 AM ---------- Previous post was at 08:56 AM ----------
Or maybe a blessing. Time for a bigger transplant
Old 09-03-2013, 12:40 PM   #18
lemons95's Avatar
If the 5.0 turns out to be too difficult. You could swap in a 4.2 easiest swap out there for the V6. Bolts right up and can use your stock heads and intake.
Old 09-03-2013, 12:45 PM   #19
351stroker's Avatar
Difficult = too much $. Lol. It would cost u more for sure. And if u do a 5.0 swap you won't go with a 5.0 you would do a 331/347. Make that baby go!
Old 09-03-2013, 12:50 PM   #20
lemons95's Avatar
If I was going to go V8 swap I get 5.0 then make sure everything works on it after the swap. And rip it out and throw a 351w in it. Wouldn't even have to stroke it. But you could stroke it out to a 408 or 427 if you modify the block.
Old 09-03-2013, 12:56 PM   #21
351stroker's Avatar
Y waste the time and money on a 5.0 then? Go straight to the 351 then. Build with forged internals and twin turbo it.
Old 09-13-2013, 08:21 PM   #22
Oh no no I'm not putting a 5.0 in the 99 v6 I have. I'm getting a stock 5.0. Fox body. I don't wanna waist time and money putting a 5.0 in my 99
Old 10-01-2013, 01:04 AM   #23
Right before I was going to sell my car a guy in a mustang pulled up to me and we realized I have a blown head gasket and that's why I was having power loss. So I'm going to replace it and flush my fluids and then put new fluid in it.
05:31 AM
