signal lights? - Mustang Evolution
Old 08-28-2013, 06:35 PM   #1
daniel95's Avatar
signal lights?
I just got a new sound system. Coukd that be why my left signal light blinks like once or twice the stops
daniel95 is offline   Reply With Quote
Old 08-28-2013, 06:37 PM   #2
sam62893's Avatar
Maybe you crossed wires or damaged one in the process
Old 08-28-2013, 06:41 PM   #3
daniel95's Avatar
Would yu ou no what wire I culd possibly check. Or could it be a bad fuse
Old 08-28-2013, 06:48 PM   #4
sam62893's Avatar
If it was a bad fuse it wouldn't click at all. It could be your flasher. It should be a yellow little electrical box under the dash on the drivers side. As for the wire it should be color coded (not sure what color) going down your steering column. I wouldn't bother with that though. Did you get a shop to do the work it did you install yourself? If it was a shop tell them to look at it. If they are professional they should fix their mistake. It could also be that they knicked a wire in your trunk
07:54 AM
