Need help - Mustang Evolution
Old 08-28-2013, 06:42 PM   #1
bkh1994's Avatar
Need help
Okay so my car was skipping *sometimes* and I tried taking the plug wires off and back on, because I replaced a sparkplug about a month ago because it was misfiring on a cylinder. So after I did that, it does alright. But it had/has rough idle and sometimes will jerk a tiny bit while driving. So I tried taking the wires off and back on and the service engine soon light came on. Any ideas why? I reset it and the light is still on. I also want to know why it will lurch/skip sometimes while driving
bkh1994 is offline   Reply With Quote
Old 08-28-2013, 06:50 PM   #2
sam62893's Avatar
Crossed some wires maybe? Recheck the routing on your coil pack and make sure you plug the wires in the corresponding cylinder
Old 08-28-2013, 06:52 PM   #3
bkh1994's Avatar
I took one off at a time so that's not the problem
Old 08-28-2013, 06:54 PM   #4
Venomouz831's Avatar
What's that code?
)02 Gt, Founder of WE2G
Old 08-28-2013, 06:56 PM   #5
bkh1994's Avatar
Originally Posted by Venomouz831 View Post
What's that code?
No clue, don't have a tuner. In the morning before school I'm gonna unplug a wire one by one and see if any aren't plugged in good (its hot right now) and if that doesn't fix it ill stop by autozone and see what they can tell me
Old 08-28-2013, 09:25 PM   #6
bkh1994's Avatar
Okay so when I took out the airbox, apparently that's what threw the code. I reset the computer again and the CEL went off. But the question still stands, what could make my idle rougher and make it skip/jerk/lurch sometimes. It might do it about every 10 minutes if that helps. It's not like a whiplash kind of jerk just like the power cuts out for a split second or something along those lines
Old 08-29-2013, 04:38 AM   #7
sebasflorez's Avatar
Try replacing the coil pack. My car was also misfiring and jerking, replaced that and problem went away
sebasflorez is offline   Reply With Quote
Old 08-29-2013, 06:05 AM   #8
bkh1994's Avatar
Is there a way to check if mine is bad? By the way, I don't know if this helps, but I did the trick where you take a wire off of the coilpack at a time to see if a plug is broke or whatever, to hunt it down. All of them shook the engine about the same amount except 1 or 2 did more than the others. And the new plug was like the others so its not that they are in better shape or anything
Old 08-29-2013, 06:13 AM   #9
Yes there is:
Old 08-29-2013, 06:19 AM   #10
bkh1994's Avatar
Thanks. I'll check it out. Other suggestions will be helpful too whoever reads this haha
Old 08-29-2013, 02:54 PM   #11
bkh1994's Avatar
Bump
Old 08-29-2013, 03:58 PM   #12
Could also be Crankshaft position sensor, Spark plug wires, or a sparkplug. Check/replace all that and it should stop.
Old 08-29-2013, 04:14 PM   #13
bkh1994's Avatar
Where and what is a crankshaft position sensor haha? I got all new plugs that I'm putting on tomorrow but I'm not sure that's the problem. And how would I check the wires? None are melted or anything
Old 08-29-2013, 04:41 PM   #14
Crankshaft position sensor is located on the passenger side of the crankshaft (the round wheel looking thing in the middle of your engine) it should look like this:
Old 08-29-2013, 04:43 PM   #15
Now to check the wires open the hood at night, turn all lights off and run the car, if the wires are bad you should see electricity arcs.
Old 08-29-2013, 05:38 PM   #16
bkh1994's Avatar
How would I check that?
And the wires are fine then, I don't see arcs at night
Old 08-29-2013, 06:47 PM   #17
There's really no way to check the CPS, but if it is not working the car should get CEL and throw a code that will say Missfire Detected Cylinder #. I replaced mine with a new one and that didn't fix my problem, but while searching for a thread that would fix my problem I found many people that said replacing the CPS fixed their problem. In the mean time do the spark plugs and check the coil pack, those are the most likely ones to be causeing the hesitation
Old 08-29-2013, 06:49 PM   #18
bkh1994's Avatar
Okay thanks a ton! I'm getting my coil pack checked by autozone tomorrow and I'll change the sparkplugs either way. They are the stock ones with 115k on them haha
Old 08-29-2013, 07:19 PM   #19
All right! Let me know how it goes, make sure to get Motorcraft sparkplugs ONLY, the stories I've heard of other brands in our cars are not pretty
Old 08-29-2013, 07:21 PM   #20
bkh1994's Avatar
I'll be sure to. And I knew they would work so I got those lol, but thanks for the heads up. Got me some Motorcraft Platinums
Old 08-29-2013, 08:16 PM   #21
Yep, same I got, no trouble and it's been 12k
Old 08-29-2013, 08:17 PM   #22
bkh1994's Avatar
Okay cool
Old 08-30-2013, 08:04 PM   #23
bkh1994's Avatar
Oh boy that is the toughest work and squeeze I've ever done lol. Got the boys on though. Took an hour and a half
Old 08-30-2013, 08:29 PM   #24
Robbiemustang96's Avatar
Lol it took me three because i have fat arms and trying to squeeze through those nrake lines were the worst.
Robbiemustang96 is offline   Reply With Quote
Old 08-30-2013, 08:34 PM   #25
bkh1994's Avatar
That side wasn't bad but the passenger side with the egr tube (i think that's what its called) was in the way on the back two. I think if it was gonna take me 3 hours id pay someone to do it lol
Old 08-30-2013, 10:57 PM   #26
Oh yes! It's tough!! So did she stop jerking?
Old 08-31-2013, 09:13 AM   #27
bkh1994's Avatar
It usually takes about 15 minutes to get it jerking. Plus I didn't drive it, just cranked it because I got finished at 9:30 and needed a shower and I was dead tired haha. I'll let you know when I take her for a drive
Old 08-31-2013, 09:14 AM   #28
All right man. Fingers crossed that fixed your problem!
Old 08-31-2013, 09:24 AM   #29
bkh1994's Avatar
Yeah I know! Thanks!
08:02 PM
