Squeak noise after lowering springs - Mustang Evolution
Old 08-29-2013, 05:49 AM   #1
sebasflorez's Avatar
So I lowered my 02 V6 with H&R Super Sports and replaced the shocks and struts, now everytime my struts compress (going over a bump) I hear a squeak noise coming from the struts, is this normal?
sebasflorez is offline   Reply With Quote
Old 08-29-2013, 06:06 AM   #2
Horseplay's Avatar
did u replace the iso's?
Low2v
Old 08-29-2013, 06:10 AM   #3
Yes I did. With SR isos from AM
Old 08-29-2013, 09:42 AM   #4
Anyone?
Old 08-29-2013, 10:48 AM   #5
sam62893's Avatar
Did you tape the ISO's to the springs? They could have moved and that's metal on metal squeaking you're hearing
Old 08-29-2013, 11:06 AM   #6
I did...
Old 08-29-2013, 11:22 AM   #7
dark2007 is offline   Reply With Quote
Old 08-29-2013, 12:59 PM   #8
RedSleeper's Avatar
Chamber plates?
Loving the days when you travel down to Mexico to push your car to the limits!
RedSleeper is offline   Reply With Quote
Old 08-29-2013, 01:56 PM   #9
Originally Posted by RedSleeper View Post
Chamber plates?
I did install cc plates, do they make that noise normally?
Old 08-29-2013, 02:02 PM   #10
RedSleeper's Avatar
No, I may be wrong. But I did hear if you didn't replace chamber plates while doing lowering springs it'd cause some noise / bumpy ride.
That's why I got cc with my lowering springs to prevent that.
But since you said you already did cc. I guess you're fine in that area.
Old 08-29-2013, 02:21 PM   #11
1slosix's Avatar
To be honest its the isolators causing the noise....they are poly not rubber I believe which are notorious for noise. You'd be better off without isolators. I don't use them and have no noise issues.
carving corners like a boss
Old 08-29-2013, 03:56 PM   #12
Well as long as it's only the isolators... Besides, you can only hear the noise while there's no music playing and 90% of the time i'm playing music in the car!
08:14 AM
