Removing Cats - Mustang Evolution
Old 08-29-2013, 12:33 PM   #1
2000v6stang's Avatar
Region: Iowa
Removing Cats
I think I have 4 cats on my 2000 3.8L and I want to remove 2 of them and just put a pipe where they used to be. How can I do this without throwing a check engine light do I need new O2 sensors or simulators? any ideas?
Blacking it out, MAC duel exhaust, SR CAI, Performance Automatic shift kit. And a long build list wrecked in July '14
2000v6stang is offline   Reply With Quote
Old 08-29-2013, 01:36 PM   #2
samuelsmith's Avatar
Mustang Plug-in MIL Eliminators at AmericanMuscle.com
Old 08-29-2013, 01:50 PM   #3
JimmyMosqueda's Avatar
You can use the above, or you can use a tuner to get rid of the code and deactivate the o2 sensors.
JimmyMosqueda is offline   Reply With Quote
Old 08-29-2013, 01:57 PM   #4
Horseplay's Avatar
^ both correct
Low2v
Old 08-29-2013, 02:49 PM   #5
bkh1994's Avatar
Or use spark plug nonfoulers (like $5) so its the cheapest
bkh1994 is offline   Reply With Quote
Old 08-29-2013, 10:45 PM   #6
lemons95's Avatar
Will that still work if you remove all the cats?
Old 08-30-2013, 02:22 AM   #7
JB_MUSTANG_V6's Avatar
What's the point in removing the cats? I think it sounds terrible IMO
JB_MUSTANG_V6 is offline   Reply With Quote
Old 08-30-2013, 06:45 AM   #8
bkh1994's Avatar
Just the back two I'm pretty sure
Old 08-30-2013, 02:51 PM   #9
Project Pony's Avatar
Listen to mine in the exhaust sticky. No cats, mac prochamber, 2 1/2" tubing with flowmaster 10's. I love the sound but even better, everyone who hears it agrees. It sounds good.
Also the stock cats are fairly restrictive.
[SIGPIC][/SIGPIC]
Old 08-30-2013, 11:00 PM   #10
Region: Iowa
ok thank you ill research my options i want to take them off because i want my car to be a little louder i mean it sounds nice it has a good tone but i want it louder also like one of you said they are restrictive.
Old 08-31-2013, 11:26 PM   #11
Region: Iowa
one where can I find the spark plug things and two how will it sound just removing two will it sound raspy or will it still be throaty I just want more volume
Old 09-01-2013, 08:02 PM   #12
If you want volume, remove all four.
[SIGPIC][/SIGPIC]
Old 09-01-2013, 09:32 PM   #13
bkh1994's Avatar
Sparkplug nonfoulers can be found at any auto parts store. If you can't find them yourself, ask an employee. They'll know what you want. I'll post up a guide on how to use them tomorrow
Old 09-02-2013, 09:32 AM   #14
Region: Iowa
I do want volume but I don't want to loose the nice tone It has
Old 09-02-2013, 10:17 AM   #15
bkh1994's Avatar
IMO I don't like the cats off. It makes it sound like a truck to me. If you want loud, glasspacks, if you want around the same tone you have now, yes remove the cats
Old 09-02-2013, 10:52 AM   #16
I though MIL eliminators have a diode in them not spark plug nonfoulers.
Old 09-02-2013, 11:47 AM   #17
Crowned1's Avatar
glass packs are for ricerzzzz
Crowned1 is offline   Reply With Quote
Old 09-02-2013, 11:51 AM   #18
bkh1994's Avatar
Im not sure what you're asking but sparkplug nonfoulers just like lengthen the o2 sensors so it can't sense it to the fullest extent
I don't like glasspacks either but if he's wanting louder than he has WITH cats then glasspacks is pretty much the loudest I can think of. Unless he wants to straight pipe it
Old 09-02-2013, 12:08 PM   #19
bkh1994's Avatar
Here is two guides on how to use sparkplug non-foulers
How to install the spark plug anti-foulers to remove the ses or cel light - evolutionm.net
$5 o2 cheater/non fouler how-to - evolutionm.net
Old 09-02-2013, 01:14 PM   #20
lemons95's Avatar
glass packs are for old school muscle cars, they shouldn't be anywhere near ricers.
Old 09-02-2013, 02:14 PM   #21
bkh1994's Avatar
+1
Old 09-02-2013, 08:36 PM   #22
Region: Iowa
I agree I don't like glass packs on mustangs I don't like rasp ether my car has a nice sound clear deep tone and I love it but its still kind of quiet I just want it louder but I don't want to change how it sounds. From what im hearing glasspack will change it so I don't want that but if I just do a straight pipe it wont change the sound just make it louder. and if I do non foulers or MIL eliminators would keep my engine light off. Am I right
Old 09-02-2013, 09:58 PM   #23
bkh1994's Avatar
Non foulers or MIL eliminators will keep the CEL off if you just remove the two back catalytic converters, yes. And by straight pipe, what do you mean? Also, what is your current exhaust setup?
Old 09-03-2013, 07:02 AM   #24
Region: Iowa
I have the MAC conversion kit so it sounds good but still not as loud as I want. By straight pipe I mean when I cut the cats off just welding a pipe in its place and putting a my O2 sensor or MIL eliminators there verses lets say a glasspack
Old 09-03-2013, 07:25 AM   #25
bkh1994's Avatar
Conversion kits aren't loud. And straight pipes means to run no mufflers, not to cut out the cats. Yes, you put a pipe in place of the cat but that's just called cutting them. And a glasspack is not used as a replacement for a cat, it is a muffler. Does that make sense?
---------- Post added at 09:25 AM ---------- Previous post was at 09:24 AM ----------
You'll want to get rid of the conversion kit or cut the cats to make it louder. Id say for loud and cheap, cut the cats and throw glasspacks on it. Not my favorite sound but its definitely loud
Old 09-03-2013, 07:33 AM   #26
Region: Iowa
yeah that makes sense I know glasspack isn't the same as a cat but ive had friends put glasspacks in place of cats instead of just doing a pipe. I just didn't know what would sound better I don't want a raspy sound
---------- Post added at 08:33 AM ---------- Previous post was at 08:31 AM ----------
could I just do a mid pipe to make it louder and not get a bad sound
Old 09-03-2013, 07:35 AM   #27
bkh1994's Avatar
I've heard of people doing that too. I was just making sure you were aware. I have no clue how it sounds. A midpipe won't fit with your conversion kit. You'll have to cut it. The only way to make yours louder WITH the kit is to cut cats or swap mufflers. Swapping mufflers would change your sound though
Old 09-03-2013, 08:14 AM   #28
Region: Iowa
ok thank you for your help and talking me through it I appreciate it!
Old 09-03-2013, 10:00 AM   #29
bkh1994's Avatar
No problem! If you have any more questions or need an opinion I can help
Old 09-03-2013, 12:38 PM   #30
lemons95's Avatar
You might be able to run straight pipes from the headers back. I've seen V8 trucks do this in my area. I heard of one guy getting a few tickets but he had open headers.
Old 09-03-2013, 12:41 PM   #31
bkh1994's Avatar
IMO straight pipe doesn't sound good on a v6. It's just loud. Not really any tone or anything
Old 09-03-2013, 05:17 PM   #32
Crowned1's Avatar
did anybody ask for your opinion?
Old 09-03-2013, 05:23 PM   #33
bkh1994's Avatar
I guess not haha :p
Old 09-04-2013, 12:04 AM   #34
lemons95's Avatar
I think if you had a good cam, full straight pipes would probably sound okay. With the stock cam, probably not.
straight pipes with cats, sounds okay though. I'm getting bored of hearing the same thing everyday though.
Old 09-04-2013, 12:45 AM   #35
davidcseifert's Avatar
Region: Arkansas
Straight pipes never sound ok..
blower/new cam soon
11:42 PM
