Shaking down the road - Mustang Evolution
Old 08-30-2013, 08:41 AM   #1
Chelley's Avatar
Hey guys here's the low down. I have a 2000 base model V6 auto with around 235000 miles on it. It has very basic intake mods, lowered suspension and a cut exhaust.
My problem, it shakes horribly when I accelerate and maintain speeds over 40 mph. Now I'm very happy in denial that this is due to my alignment being awful, tires about done and leaking gaskets. It did have a mis problem caused by loose coil connections but the shaking came back.
However it is getting worse. The transmission was rebuilt a couple of years ago so I am going to do a fluid and filter change including the torque converter see if the fluid can tell me anything, as well as the gaskets, suspension and tires.
There are many other things wrong with it but are not related but if anyone has any suggestions as to what it might be it would be a huge help. Thanks.
Chelley is offline   Reply With Quote
Old 08-30-2013, 09:23 AM   #2
sam62893's Avatar
Check the rear u joints they may be shot
Old 08-30-2013, 10:05 AM   #3
Chelley's Avatar
Will do, thanks.
Old 08-30-2013, 10:17 AM   #4
bigmac3's Avatar
Originally Posted by Chelley View Post
...I'm very happy in denial that this is due to my alignment being awful, tires about done...
My guess is shot tires badly out of balance. If you have a customer account at Discount Tire, have them check you balance, otherwise if maybe you have a friend with a Mustang that doesn't have a shake issue, see if you can swap tires/wheels to check if it goes away. Good luck.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 08-30-2013, 10:31 AM   #5
tc x 4's Avatar
Could be a hundred different things, u-joints is where I'd start too.
Old 08-31-2013, 03:36 PM   #6
Chelley's Avatar
Thanks guys. I know my tires are bad and my wheels are not balanced. After I've replaced the ball joints, put the caster/camber kit on, I'll be doing new tires and alignment. I'll check out the u joints when I have it on the lift again.
Old 08-31-2013, 03:48 PM   #7
02GTvert's Avatar
Yea a lot of things..but definitely an alignment if you never did after it was lowered and put CC plates on. And a new set of tires.
02GTvert is offline   Reply With Quote
Old 09-01-2013, 09:11 PM   #8
Blakhwk's Avatar
First you have to check if the shaking happens while driving, or also when you push the gas while on park!
Visca Barça
Blakhwk is offline   Reply With Quote
Old 09-01-2013, 09:27 PM   #9
blackhawk 1's Avatar
the car may have been hit
blackhawk 1 is offline   Reply With Quote
Old 09-02-2013, 03:43 PM   #10
Chelley's Avatar
The shaking goes away when you put it in neutral while your driving, the transmission was rebuilt a couple of years ago and the vehicle has been in an accident. I have no info on the accident though.
12:02 AM
