Cutting Springs - Mustang Evolution
Old 08-31-2013, 05:36 PM   #1
bkh1994's Avatar
Cutting Springs
Does anyone know of a detailed write up for this? I need as much help as I can get lol. Also I want to know if it really is bad for the suspension. I've been looking all day and the majority says no but the few who says yes, fully agree. My suspension squeaks enough as it is, I don't want to mess anything up. But I really want it lowered. Lowering springs are too expensive and pointless if you can just cut the ones I got. Just need advice/suggestions, etc
bkh1994 is offline   Reply With Quote
Old 08-31-2013, 06:07 PM   #2
sebasflorez's Avatar
Go ahead and cut your springs man, though if you lower it over 1" your shocks and struts will die in less than a year. If you do lower get shocks and struts when you get a chance.
sebasflorez is offline   Reply With Quote
Old 08-31-2013, 06:11 PM   #3
bkh1994's Avatar
I'm not sure how good mine are to begin with. They are probably the original shocks and struts and I'm at 116k lol. Pretty much everything is stock. Even my sparkplugs were until yesterday lol. But if I would have to get new shocks and struts, wouldn't it be better just to get springs? Lol I'm confused
Old 08-31-2013, 06:19 PM   #4
It's safe to cut 1 coil off your springs, that should lower you about 1.5" but you'd need caster camber plates to align the car correctly and in the long run new shocks and struts. Since my car had 94k I figured i'd just replace my whole suspension, lol, but that's just me. I've heard if you cut more than 1 coil off your spring it's bad because spring rate won't increase enough
---------- Post added at 07:19 PM ---------- Previous post was at 07:16 PM ----------
This is a write up I found for 03-04 Cobras, should be about the same for you, but don't cut more than 1 coil off! Lol
http://www.svtperformance.com/forums...gs-thread.html
Old 08-31-2013, 06:51 PM   #5
bkh1994's Avatar
One coil is right at what I want in the front and probably .75 of the back, whatever would give me about 1". And I don't know hardly anything about cars so I'd need an exact write up lol
Old 08-31-2013, 07:22 PM   #6
Here ya go, this one is for GT, but it's 99% the same for a V6, differs only on wether or not you have ABS. Let me see if I can find the video I used to do mine.
http://www.moddedmustangs.com/forums...ustang-gt.html
---------- Post added at 08:22 PM ---------- Previous post was at 08:19 PM ----------
Here you go, use these:
http://youtu.be/eoRnPx9-Fc8
http://youtu.be/QCfzpvv3jF8
I hope they help!
Old 08-31-2013, 08:23 PM   #7
1slosix's Avatar
Cut 1.25 off the front and 1 off the back. I would trash the isolators as well..I have cut over 6 new edge mustangs with that setup all running stock shocks and struts...also I've been lowered to 1.5" for years on stock shocks and struts at that. I do say an upgrade would do you nicely if you have bad shocks and struts now but its not needed to lower it safely. What do you want to know that the cobra write up I told you about didn't cover? Its pretty much pulling out the springs...using one method or another to cut the spring (never with heat or a cutting torch) and putting them back in.
carving corners like a boss
Old 08-31-2013, 08:59 PM   #8
bkh1994's Avatar
Could I just use a saw? And I just want it as close as possible so I don't mess up anything. I'm not confident when it comes to cars haha. Don't get me wrong, I appreciate the help, but I wanna do it right the first time. How much would it drop with 1.25 on front and one in back? Got a picture for the drop also? Thanks both for the guide!!
Old 08-31-2013, 09:44 PM   #9
1slosix's Avatar
close to 1.5" and well here's pics of my last two stangs cut like that
Old 08-31-2013, 10:07 PM   #10
bkh1994's Avatar
Looks good. And that's without isos? Also I wouldn't rub with 16" rims would I?
Old 08-31-2013, 10:55 PM   #11
sam62893's Avatar
16? Nahh. I cut my springs. I would go with slo's setup. I messed up with my springs when I cut them. I cut 1.5 from the back and 1.75 in the front. Way too low for me. Rubbed everywhere, exhaust hit everything. I think I had like less than an inch clearance from the floor with my cats and mufflers. I ate up a huge chink of my fender liner as well. The next day I got a spare set of front springs and just cut one coil and kept ISO's. now my suspension is lopsided. Cut 1 in front and 1.5 in the rear
Bad drop 1.75 cut front
Lop sided drop 1cut front
Old 09-01-2013, 06:56 AM   #12
bkh1994's Avatar
What is that first and second picture? The front looks a little too low for what I want
Old 09-01-2013, 08:13 AM   #13
bkh1994's Avatar
Also, would a saw work for it?
Old 09-01-2013, 10:07 AM   #14
sam62893's Avatar
First pictures are 1.75 up front and 1.5 in the rear. Last two are 1 in the front and 1.5 in the rear. Doesn't really look lifted though. It would take forever with a hand saw. The metal is just too thick
Old 09-01-2013, 01:04 PM   #15
1slosix's Avatar
I agree..spend $20 on a cheap saw...could use either a saw saw but I prefer metal grinding wheel.
Old 09-01-2013, 01:06 PM   #16
bkh1994's Avatar
I have a friend with a grinder. I'll see if I can borrow it
Old 09-01-2013, 05:25 PM   #17
SpeedyG's Avatar
How much is the recommended cut for a vert with stock springs?
SpeedyG is offline   Reply With Quote
Old 09-01-2013, 05:33 PM   #18
1slosix's Avatar
The same 1.25 and 1 will do
09:48 AM
