Ticking - Mustang Evolution
Old 09-01-2013, 06:16 PM   #1
Chapka's Avatar
Ticking
So lately I've been hearing ticking from the engine on the passenger side. It only seems to tick on a cold starts in the mornings, i leave for work at 4am. The ticking stops after driving a few feet down the road. And doesn't tick after sitting in the parking lot in the sun all day when I leave work. I don't think it's the exhaust manifold. What else could it be? And is it something serious?
America is all about speed - hot, nasty, badass speed
Chapka is offline   Reply With Quote
Old 09-01-2013, 06:30 PM   #2
KamzGT's Avatar
U have oil in the motor?
KamzGT is offline   Reply With Quote
Old 09-01-2013, 07:28 PM   #3
Chapka's Avatar
Yes. I jst did an oil change this afternoon
Old 09-01-2013, 07:39 PM   #4
KamzGT's Avatar
U check spark plugs? Wires? Fuses?
---------- Post added at 06:39 PM ---------- Previous post was at 06:38 PM ----------
Exhaust leak?
Old 09-02-2013, 02:34 PM   #5
bkh1994's Avatar
I'm betting it is an exhaust leak in your manifold on the passenger side. It ticks on start up because its a cold start. You can't hear it later because it has heated up and the metal expands to cover the hole more
bkh1994 is offline   Reply With Quote
Old 09-02-2013, 02:35 PM   #6
Chapka's Avatar
Exhaust leak?
Plugs wire and fuses seem to be in order. I'm not sure about an exhaust leak. Wouldn't an exhaust leak tick entire time car in running
Old 09-02-2013, 02:37 PM   #7
bkh1994's Avatar
No. Just on start up, until it heats up for a minute or two
Old 09-02-2013, 04:20 PM   #8
Chapka's Avatar
You know that makes sense. I did do exhaust work last week. Maybe something got tweaked. What would a solution be? New manifolds? Or is there something else? Maybe get some headers
Old 09-02-2013, 05:27 PM   #9
bkh1994's Avatar
If one is cracked, I would get you a set of shorty headers. Get a tiny bit more air flow and a replacement. If you want a temporary solution, you could get the hole welded over if its not too big
Old 09-02-2013, 05:50 PM   #10
KamzGT's Avatar
Exhuast leak doesn't always tick all the time, remember when somthing is cold it tends to shrink, now when somthing heats up it expands. Therefore when your manifold get hot it expands, when it's cold it goes back to the original fitment leaving a hole somewhere if there is a hole. I hope this makes sense to you
Old 09-02-2013, 06:09 PM   #11
Chapka's Avatar
It all makes sense. Anyway to fix it? Or take this as a time to get headers?
Old 09-02-2013, 06:20 PM   #12
bkh1994's Avatar
Weld it for a little while or headers or you can just replace that side. You can get pacesetter headers for 120
Old 09-02-2013, 08:38 PM   #13
KamzGT's Avatar
Honestly do it right the first time, get new headers. Get somthing that you will like that will give u some hp and good sound too, that way u only have to do it once
---------- Post added at 07:38 PM ---------- Previous post was at 07:37 PM ----------
Replace both at same time.
Old 09-02-2013, 10:00 PM   #14
bkh1994's Avatar
+1
Old 09-03-2013, 02:32 AM   #15
Chapka's Avatar
+1
Is it something that should be done right away? I want to get a mach 1 over the winter. And I'm saving every dime possible. Is there a way to find the whole and weld it?
Old 09-03-2013, 05:27 AM   #16
bkh1994's Avatar
No its not a huge hurry. It'll just get bigger, make noise, affect your gas mileage and performance a tiny bit. But yeah you can weld it and it'll *should* hold up for the few months you need it to
Old 09-03-2013, 07:42 AM   #17
Chapka's Avatar
Alright perfect. All it's gotta do it last until holloween, then she goes I to storage. How hard is it gonna be to find the hole?
Old 09-03-2013, 07:45 AM   #18
bkh1994's Avatar
Not too hard. A few ways you can do it. Get a mechanic stethoscope or vacuum hose and listen for the tick until you can pinpoint it. Or just feel for air coming out. I suggest you check the flange collector (where it connects to the y pipe) because the ac water drips on it
Old 09-03-2013, 03:35 PM   #19
Chapka's Avatar
Doesn't seem to bad. Thanks. I'm gonna give it a try over the weekend
Old 09-03-2013, 04:11 PM   #20
bkh1994's Avatar
No problem! Just let me know if you have any more questions
Old 09-04-2013, 08:50 PM   #21
Just_John's Avatar
Region: South Dakota
If you did exhaust work recently, go and re-torque any nuts or bolts you played with. Heat and time tend to cause expansion and contraction of exhaust systems. Much like the need to re-torque header bolts after a few hours of driving, any other connection point is subject to the same thermal abuses. Get under the car and tighten everything up again.
01 V6 5 spd
Windstar upper, shorty headers, high-flow catted X, American Thunder catback, SCT Tuner, ASP 25% UDP, FRPP T-Lok
Just_John is offline   Reply With Quote
Old 09-04-2013, 08:55 PM   #22
bkh1994's Avatar
+1 I still have to do that to my headers /:
Old 09-04-2013, 10:48 PM   #23
samuelsmith's Avatar
Can any one name 10 mustang forums.
mustangevolution
v6power.net
mustangforms
mustang6g
3.7mustang
I can only get 2 five
Old 09-05-2013, 05:29 AM   #24
bkh1994's Avatar
mustangevolution
v6power.net
mustangforms
mustang6g
3.7mustang
Moddedmustangs.com
Allfordmustangs.com
» Members Mustangs
GTee
ShelbyGTee
Elle
Bleem@1
Add your Mustang
09:55 AM
