98 stang - Mustang Evolution
Old 09-01-2013, 11:31 PM   #1
daniel95's Avatar
98 stang
Would it be possible to put a 1990 5.0 engine in my 98 v6
daniel95 is offline   Reply With Quote
Old 09-02-2013, 12:34 AM   #2
Robbiemustang96's Avatar
Its not impossible to do no. But what you need in order to do it is a 94-95 v6/gt k member. Depending on the tranny im not sure. Either carb it or find a 94-95 ecu and wiring harnesses.
Robbiemustang96 is offline   Reply With Quote
Old 09-02-2013, 10:55 AM   #3
samuelsmith's Avatar
I've see a 5.0 in a 99
Old 09-02-2013, 01:52 PM   #4
ProjectTurboV6's Avatar
You could successfully put a 7.3 powerstroke into your mustang lol any engine will work if you create the right motor mounts, have the ecu, matching drivetrain/rear, and some mechanical knowhow. You have the whole 1990 car so this should be a very simple swap for you.
ProjectTurboV6 is offline   Reply With Quote
10:27 AM
