fog lights - Mustang Evolution
Old 09-02-2013, 10:45 PM   #1
daniel95's Avatar
fog lights
What do I need exactly to install fog lights in a 1998 v6
daniel95 is offline   Reply With Quote
Old 09-02-2013, 11:11 PM   #2
1slosix's Avatar
1. fog lights
2. toggle switch
3. a spool of wire and crimp ends
pretty much that
carving corners like a boss
Old 09-02-2013, 11:17 PM   #3
sam62893's Avatar
Originally Posted by 1slosix View Post
1. fog lights
2. toggle switch
pretty much that
Can't you also splice them onto your already existing headlight switch? Turn them on when you pull it out halfway
Old 09-02-2013, 11:33 PM   #4
1slosix's Avatar
you can splice them to your ambers constant power wire for a more oem effect..half pull the switch to turn on fogs then full pull to keep them on and add the headlights on as well. i only run a seperate wiring setup because i've run 55w hid fogs before lol and i don't wanna chance my turn signals smaller wires. but for 35w hids or standard halogen fogs that'd work great
Old 09-05-2013, 04:40 AM   #5
Ghostedmind's Avatar
vmptuning.com has a kit that is supposed to plug in (basically the OEM system) and its supposed to be just like you car came with them from the factory for $180
LCMC Member
Old 09-09-2013, 09:40 AM   #6
nekronos's Avatar
Send a message via AIM to nekronos
you can buy the oem switch that goes into the console below your stereo for about 40 bucks, you don't need that kit from vmptuning (that's way overpriced anyways)
2001 V6 Vert
CAI, Roush Front bumper, OEM Cobra ducktail spoiler, MGW shifter, 2.5" True Duals w/ flowmasters, FR500 steering wheel, Dual HID headlights and foglights, hood struts, shorty antenna.
Soon: Eibach Pro-kit, Bilstein/Tokico HP shocks/struts, Light bar, 17" Chrome FR500 wheels, .
nekronos is offline   Reply With Quote
Old 09-09-2013, 10:13 AM   #7
Are you talking about this switch?
Genuine 1998 Ford Mustang Factory Parts - BlueSpringsFordParts.com
01LaserCobra is offline   Reply With Quote
Old 09-09-2013, 10:28 AM   #8
nekronos's Avatar
unfortunately that link doesn't go to the part, bad website design but I think so, I looked for it and found item #11 says about 44 bucks - switch assembly fog lamp. I have a 2001 so it was a bit different but same thing.
http://www.bluespringsfordparts.com/...gramCallOut=11
2001 V6 Vert
05:06 PM
