Need help please.. - Mustang Evolution
Old 09-05-2013, 09:33 AM   #1
Need help please..
I have a 2000 Mustang V6 3.8. Sometimes when I am driving it will loss power(electrical) power like the batt. has came disconnected. But it is only for a split sec or two and come right back on. Also sometimes after driving it, I will got to get start it up and the car has no power at all. Its like the batt. I have no power what so ever. And I will trun the key off and wait bout 5 or so mins and try to start it again and will have power and start right up. But while waiting for it I will jiggle the batt cables, I habe replaced all the batt cables pos. and neg. and I am still having the same problem. Does any one have any ideas please??.
smokeater823 is offline   Reply With Quote
Old 09-05-2013, 10:00 AM   #2
1slosix's Avatar
Test the alternator
carving corners like a boss
Old 09-05-2013, 10:06 AM   #3
It's not me, it's you.
primer2tone's Avatar
You've replaced the positive & negative cables or the terminals? Double check where they are connecting. Be sure there is no corrosion.
Old 09-05-2013, 10:07 AM   #4
ok thanks
Old 09-08-2013, 05:23 AM   #5
PureInstinct's Avatar
Primer2tone is correct, you should check the cables and terminals and make sure that nothing is loose and everything is connected properly. Last thing you want is your car turning off at the worst time possible.
PureInstinct is offline   Reply With Quote
05:03 AM
