All power drained at once? - Mustang Evolution
Old 09-08-2013, 02:07 PM   #1
SpeedyG's Avatar
A weird thing happened this morning. I was driving home from work and when i parked my car at my house for 10 minutes then went back in to go out my whole car had died. Electrical nothing worked, door locks, lights, dash, radio, starter, nothing. I got a jump start then everything was fine then when I came back from a quick drive and parked the same thing happened again? Could it be battery or alternator? Or something else.
SpeedyG is offline   Reply With Quote
Old 09-08-2013, 02:29 PM   #2
samuelsmith's Avatar
It could be a short, but I would have my battery tested first.
Old 09-08-2013, 04:35 PM   #3
1slosix's Avatar
i'd say battery...if you drove it then the alternator is working
carving corners like a boss
Old 09-08-2013, 05:09 PM   #4
Robbiemustang96's Avatar
Check your terminals too.
Robbiemustang96 is offline   Reply With Quote
Old 09-08-2013, 05:12 PM   #5
Mustang81596's Avatar
+1 this was my problem. After I fixed the connection it ran good as new
pypes x w/flow 40's, SR CAI, plasti dipped (emblems, stripe, rear decklid, rear valance, cowl vent grille, fuel door, antenna holder), shorty antenna, mach 1 chin spoiler, custom interior trim, blue LED interior lights, more to come later
Mustang81596 is offline   Reply With Quote
Old 09-08-2013, 05:16 PM   #6
sam62893's Avatar
I'd say battery as well. Mine did the same thing. Worked fine at the drive in. Went home and wouldn't turn on the next morning. Jump started it and worked fine for a while. Voltage dropped for any little thing I did.
Old 09-08-2013, 06:07 PM   #7
SpeedyG's Avatar
Thanks guys, I dropped off the battery to be charged overnight at autozone so we shall see in the morning. I've never seen the battery drained to the point where the autolocks and dash do not work. Strange, battery is 4 months old, dura last red top
Old 09-08-2013, 07:00 PM   #8
sam62893's Avatar
Why do you think autozone has such long warranties on their batteries? Lol
Old 09-08-2013, 07:21 PM   #9
Duralost jj I like getting in the zone
If you put ky jelly or grease on the terminals they will not corrode
Old 09-08-2013, 10:05 PM   #10
SpeedyG's Avatar
Ky jelly lol
Old 09-09-2013, 09:32 AM   #11
Ky jelly lol
Spank-tro-vision lube
LMAO it has multiple uses.
Old 09-09-2013, 10:04 AM   #12
Doe_Rae_mi's Avatar
It's your battery, prolly left ur lights on
Old 09-09-2013, 10:27 AM   #13
SpeedyG's Avatar
It was during day time. No lights used.
Old 09-09-2013, 10:28 AM   #14
Doe_Rae_mi's Avatar
That's weird man
Old 09-09-2013, 10:31 AM   #15
sam62893's Avatar
That's weird man
Batteries die out if the blue sometimes
Old 09-09-2013, 10:45 AM   #16
Pony_Boy's Avatar
Did you check the alternator? Charging system problems can seem like the battery... You could have damaged the alternator with the last battery if it was dead for a while. Could also be a bad cell... Some batteries last a few months, others can last six years.
Pony_Boy is offline   Reply With Quote
Old 09-10-2013, 06:41 AM   #17
SpeedyG's Avatar
Problem was the battery. Died only after 4 months of use. But lifetime warranty at autozone
Old 09-10-2013, 07:43 AM   #18
Pony_Boy's Avatar
Good warranty then!
Old 09-10-2013, 03:21 PM   #19
unrealstang's Avatar
it was most likely just a loose terminal i lost all power driving for a sec then kicked back in.. i was like ummm ok got to my location car just shuts off no power at all.. pop hood wiggles terminal that wasnt super loose turned key bam powered on.
03 Mustang 3.8
Mods
CAI Mgnaflow full exhaust
unrealstang is offline   Reply With Quote
Old 09-10-2013, 04:50 PM   #20
SpeedyG's Avatar
I know the problems loose or even corroded/acidified terminals can cause. Mine were tight and clean as can be. I put in aftermarket terminals a year ago.
Old 09-10-2013, 07:09 PM   #21
SpeedyG's Avatar
Ok, I did end up having a bad battery but now I have the same problem! Battery worked when I installed at store, got home, then I wAntex to go out now and nothing. Absolutely no electricity no where, no dash, headlights, dome, radio. So frustrated
Old 09-10-2013, 07:18 PM   #22
Redo the connection to the terminals. That was my problem
Old 09-10-2013, 09:23 PM   #23
SpeedyG's Avatar
Do you mean the connection to the terminals on the battery posts? I will try
Old 09-12-2013, 02:04 PM   #24
SpeedyG's Avatar
Does anyone know how to test the starter or starter solenoid? W/o taking it out. 2000 v6
Old 09-13-2013, 12:01 AM   #25
Pony_Boy's Avatar
If the starter were bad the dash would still turn on... Sounds like a grounding issue completely draining the battery.
Old 09-13-2013, 10:36 AM   #26
andregayola's Avatar
Hey speedy you install the springs i gave you yet?
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 09-14-2013, 04:27 PM   #27
SpeedyG's Avatar
Hey man, I have cut them already. But I'm waiting for my tokico blues to come in and do springs and shocks/struts at the same time.
Old 09-16-2013, 05:33 PM   #28
Problem under control ?
Old 09-19-2013, 04:59 PM   #29
SpeedyG's Avatar
Not yet, still trying to diagnose myself. All arrows are pointing towards the starter
Old 09-20-2013, 03:36 PM   #30
SpeedyG's Avatar
After a week of research and digging into various budgets I was able to solve my problem. It was the starter/solenoid that gave out causing a Loss of power thought the whole car losing all power at once when trying to start car. As to why the starter causes a complete electrical failure is beyond me, but I got a brand new one and it starts like new. Advice to everyone, patience is the key to removing the starter and even MORE patience and access to a variety of tools is essential for installing it again.
Remove it, have it tested, then if bad buy a new one, install, enjoy.
Thanks everyone
10:56 AM
