why isn't my service light turning on.? - Mustang Evolution
Old 09-09-2013, 12:07 AM   #1
PiojoA7x's Avatar
When I Turn on my start switch my service light doesn't turn on?
PiojoA7x is offline   Reply With Quote
Old 09-09-2013, 12:17 AM   #2
irishn8's Avatar
Maybe a previous owner cut a wire coz it was always on? Do u have aftermarket exhaust or tune? Could also be a burned out bulb, or removed bulb.
Old 09-09-2013, 12:23 AM   #3
irishn8's Avatar
A good way to see if it works is to unplug a spark plug wire while running and see if it comes on, it should throw a miss-fire code. Unplugging the MAF would work but might not come on right away. U could unplug the Idle Air Control then start the car and the light would be on if it were working at all. U could unplug the crankshaft position sensor then when you try to start it, the light would come on if it were working. If any or any combination of those dont work, you should check the bulb then wiring.
Old 09-09-2013, 01:50 PM   #4
davidcseifert's Avatar
Region: Arkansas
You shouldn't have to unplug anything for the light to come on with the first turn of the key lol (assuming service light means check engine light OP)
The bulb is most likely blown out and is easily replaced, take off the gauge cluster trim and undo the bolts holding in the cluster itself. Once you pull it out locate which little light it is and pull it out, it just twist out of place.
blower/new cam soon
Old 09-10-2013, 08:31 PM   #5
irishn8's Avatar
Yes u are right, that just to make sure, there is another reason that it doesnt come on. I was helping a friend work on his explorer and he cel didnt come on when you turned the key but it did work. I dont remember what the problem was right off though.
Old 09-15-2013, 11:21 PM   #6
PiojoA7x's Avatar
I'll check tomorrow to see if its the bulb.
Old 09-15-2013, 11:48 PM   #7
1slosix's Avatar
yep...takes all of one torx bit to do and 10-15 minutes
carving corners like a boss
Old 09-16-2013, 11:11 PM   #8
PiojoA7x's Avatar
Yeah it was the bulb. I just switched it with the bulb from the over drive, since my car is manual transmission I don't think ill need it.
Old 09-17-2013, 12:23 AM   #9
Region: Arkansas
Nice
blower/new cam soon
Old 09-18-2013, 09:06 AM   #10
PiojoA7x's Avatar
But now my service light stays on .
It looked better turned off haha....
Old 09-18-2013, 11:43 AM   #11
Region: Arkansas
What's the code(s)?
blower/new cam soon
Old 09-18-2013, 12:00 PM   #12
PiojoA7x's Avatar
What's the code(s)?
I haven't gotten checked. I'll take it to auto zone as soon when I have time
Old 10-03-2013, 12:42 PM   #13
PiojoA7x's Avatar
So I disconnected the battery and when I connected it back the service light went away. But a week later it turned on again.
Old 10-03-2013, 01:11 PM   #14
Region: Arkansas
Yep.. It resets the computer for a little while doing that, the fact it reoccurred means you have a problem that needs fixed..
blower/new cam soon
Old 10-03-2013, 08:40 PM   #15
PiojoA7x's Avatar
Gotcha!
Old 10-06-2013, 10:04 PM   #16
SueK's Avatar
Or if you had it repaired a while back maybe you need to use programer or scanner to clear the code. Ask Autozone to check for codes. No codes then ask them if they can clear it with their scanner.
SueK is offline   Reply With Quote
10:59 PM
