Benefits of short shifter? - Mustang Evolution
Old 09-09-2013, 12:41 PM   #1
KamzGT's Avatar
Is it just for looks or will it make my shifts smoother and easier???
KamzGT is offline   Reply With Quote
Old 09-09-2013, 12:45 PM   #2
MidnightBlueGT's Avatar
Yes it improves shifts, stiffness and noise. I recommend mgw
Old 09-09-2013, 12:59 PM   #3
nekronos's Avatar
Send a message via AIM to nekronos
The shifter itself doesn't change the look unless you change the boot or shifter knob.
An aftermarket short throw shifter, depending upon the one you get, shortens the throw of your shift effectively making it quicker. Some allow for a shorter/longer reach of the shifter so its easier to grab as well as the ability to reposition the handle.
The MGW (what I use) is a good example, it is adjustable (handle height) and can also be rotated 360 degrees for a more comfortable position.
MGW also has a stopping mechanism to safeguard against power shifting so as not to damage your transmission if you slam the gear.
Also a complaint I've heard with this model stang is it is easy to miss third, this shifter makes each gear feel distinct and feels very solid with each shift so you don't miss a gear.
I'm not sure that it necessarily makes it "smoother"
2001 V6 Vert
CAI, Roush Front bumper, OEM Cobra ducktail spoiler, MGW shifter, 2.5" True Duals w/ flowmasters, FR500 steering wheel, Dual HID headlights and foglights, hood struts, shorty antenna.
Soon: Eibach Pro-kit, Bilstein/Tokico HP shocks/struts, Light bar, 17" Chrome FR500 wheels, .
nekronos is offline   Reply With Quote
Old 09-09-2013, 01:04 PM   #4
Just_John's Avatar
Region: South Dakota
+1
Absolutely the BEST aftermarket shifter I have owned since I started driving in 1980!!!
I have the factory boot, but I did buy the black knob with grey stripes and numbers.... It matches the car...
01 V6 5 spd
Windstar upper, shorty headers, high-flow catted X, American Thunder catback, SCT Tuner, ASP 25% UDP, FRPP T-Lok
Just_John is offline   Reply With Quote
Old 09-09-2013, 01:28 PM   #5
Grrrr....'s Avatar
I recently put a 160 dollar B&M shifter in my 98 GT. I love it. It really pops in and out of gear now and third gear is effortless. It really cleaned my shifts up. Mine's not adjustable but it's at the perfect height. Easy to install too, all done inside the car. Just pick up some Permatech gasket maker for the install.
Grrrr.... is offline   Reply With Quote
Old 09-09-2013, 01:44 PM   #6
1lowGT's Avatar
I got the pro5.0 and its good too. If I had extra money or stock shifter I'd go with MGW
Old 09-09-2013, 04:02 PM   #7
KamzGT's Avatar
Thanx guys your very helpful!!! Y'all rock!! Now when I am at 4k rpm in 1st going into 2nd will it still shift smoother than factory???
Old 09-09-2013, 04:53 PM   #8
Grrrr....'s Avatar
That all depends on you lol
Old 09-09-2013, 05:05 PM   #9
samuelsmith's Avatar
While you are thinking about it, I have all ready short shifted. Also your elbow will not hit the console.
Old 09-11-2013, 04:10 AM   #10
SonicBlueRider's Avatar
Smoothness of the shift will depend more on your trannys condition and the fluid more than the shifter. I recently purchased an MGW shifter and it is awesome. Short throws and firm shifts. Maybe a tad bit smoother as well but I did fluid change and shifter at the same time. Hope this helps
SonicBlueRider is offline   Reply With Quote
Old 09-11-2013, 09:29 AM   #11
Crowned1's Avatar
It's really rough IMO. I'd recommend driving a car with one before buying one.
Crowned1 is offline   Reply With Quote
Old 09-11-2013, 02:02 PM   #12
KamzGT's Avatar
Thank you! I been craving mgw, I hear great things about them
10:35 PM
