T5 ratios - Mustang Evolution
Old 09-10-2013, 08:11 AM   #1
Surffer227's Avatar
T5 ratios
I've heard if you swap the trans for the t5 in the 4 cylinder mustang it has better gearing ratio, anyone know the actual ratios between stock 01 v6 t-5 and the 4cylinder fox body, also does the input shaft work?
Surffer227 is offline   Reply With Quote
Old 09-10-2013, 10:29 AM   #2
davidcseifert's Avatar
Region: Arkansas
Not sure on input shaft for the 4 bangers, but they have steeper 1st and 2nd gears
blower/new cam soon
Old 09-10-2013, 10:38 AM   #3
Surffer227's Avatar
Think this would be a good upgrade ontop of 3.73s?
---------- Post added at 12:38 PM ---------- Previous post was at 12:36 PM ----------
Think this would be a good upgrade on top of 3.73s
Old 09-10-2013, 10:43 AM   #4
Region: Arkansas
I wouldn't waste the time honestly, your trans is set up nicely just like any normal T-5 will be limited to 350ft-lbs before it starts going down the drain (which won't be a problem for most sixer guys lol)
blower/new cam soon
Old 09-10-2013, 10:53 AM   #5
Surffer227's Avatar
Well my 2nd and 5th gear are totally blown it pops me out of gear sometimes, so I was just thinkin about different kinds of trans
Old 09-10-2013, 04:07 PM   #6
Surffer227's Avatar
No one knows about these?
Old 09-11-2013, 08:14 PM   #7
97cutomstang's Avatar
Hey i just came across this and thought it might hopefully help you.
Ford Mustang: Mustang Tech: Transmission and Drivetrain: Borg Warner T5 Transmission data
97cutomstang is offline   Reply With Quote
Old 09-12-2013, 10:31 AM   #8
Surffer227's Avatar
Thanks!!,
So if anyone was intrested you can get a little better gearing with the t-5 from the 93-94 5.0 same 1st gear ratio so 1st won't be completely useless, 2nd and 3rd are a little taller wich should help with acceleration, 4th is still 1-1 and 5th is longer than ours, so if you have 3.73s this is a much better overdrive for cruising than ours, and input shaft is the same and the same length, holds a little more torque too
» Members Mustangs
Smurfy
Hmiller
GIXX
Gixx
Add your Mustang
03:48 AM
