Rough idle before throttle body cleaning, worse after - Mustang Evolution
Old 09-10-2013, 12:00 PM   #1
Question Rough idle before throttle body cleaning, worse after
Today i took my 2003 v6 mustang to the shop to try and figure out what was causing my stang to idle rough occasionally when i would come to a stop, i was told by the shop that my throttle body was very gunked up and needed to be cleaned, so they did, and cleaned the IAC, shortly after leaving i came to a stop at a stop light and the RPM's dropped even further than before, and if left in drive at a light long enough will continue to drop and recover over a minute or two. is this a vacuum leak, or does the ECM need to be reset? Also, very new mustang owner, still trying to learn.
11CharlesB is offline   Reply With Quote
Old 09-10-2013, 02:13 PM   #2
Crowned1's Avatar
try cleaning your MAF
Crowned1 is offline   Reply With Quote
Old 09-10-2013, 02:59 PM   #3
cleaned it shortly after coming home from the shop, did nothing.
Old 09-10-2013, 03:05 PM   #4
also should ad that the car has a SR CAI ( previous owner put it in) and dual slp loud mouth exhaust system (also by the previous owner)
Old 09-10-2013, 03:13 PM   #5
unrealstang's Avatar
make sure the CAI is installed properly i had same problem but it was just slightly off
03 Mustang 3.8
Mods
CAI Mgnaflow full exhaust
unrealstang is offline   Reply With Quote
Old 09-10-2013, 03:15 PM   #6
samuelsmith's Avatar
Sometimes the answer is in the comp. Autozone will test it for free
Old 09-10-2013, 04:05 PM   #7
what was off about your CAI?
Old 09-10-2013, 06:21 PM   #8
No codes could be pulled from the computer, CAI is hooked up properly as far as i can tell, maybe a reset is in order.
11:04 PM
