Shift kit? - Mustang Evolution
Old 09-12-2013, 09:12 AM   #1
2000v6stang's Avatar
Region: Iowa
Shift kit?
Does this do the same thing as a computer chip would do for my transmission? Can I do a chip and this? If I can would it make any sense to do so or would it be doing the same thing twice? Also will it really help my transmission last longer
Blacking it out, MAC duel exhaust, SR CAI, Performance Automatic shift kit. And a long build list wrecked in July '14
2000v6stang is offline   Reply With Quote
Old 09-12-2013, 11:30 AM   #2
davidcseifert's Avatar
Region: Arkansas
An actual shift kit will increase the life of the transmission as it makes shifts quicker and fluid flow easier (less time spent between gears means less wear), a tune would mimic this with high fluid pressure instead of increased flow, and not actually improve the transmission itself. If you get a tune on a car with a shift kit tell them to leave the trans settings stock or close to it so it won't interfere.
blower/new cam soon
Old 09-12-2013, 11:53 AM   #3
Region: Iowa
ok thank you so much that was just what I was looking for! so I saw springs in the kit what am I going to have to do to get it installed?
Old 09-13-2013, 02:03 AM   #4
Where do you plan to buy the shift kit in american muscle .?
el_kike956 is offline   Reply With Quote
Old 09-13-2013, 09:35 AM   #5
kickerofdoom's Avatar
Do a j mod it's the same as a shift kit but cheaper
Old 09-13-2013, 09:57 AM   #6
Mustang81596's Avatar
+1 I only hear good about jmod. A couple of bits and a gasket and you're good, correct?
pypes x w/flow 40's, SR CAI, plasti dipped (emblems, stripe, rear decklid, rear valance, cowl vent grille, fuel door, antenna holder), shorty antenna, mach 1 chin spoiler, custom interior trim, blue LED interior lights, more to come later
Mustang81596 is offline   Reply With Quote
Old 09-13-2013, 10:44 AM   #7
Whats a j mod ?
Old 09-13-2013, 11:51 AM   #8
Originally Posted by el_kike956 View Post
Whats a j mod ?
You drill a couple of holes in your transmission to allow better flow of fluid. Makes the shifts firmer
Old 09-13-2013, 11:51 AM   #9
Region: Iowa
yeah I was going to get the one on American Muscle. What is a j mod? it does the same thing for less?
Old 09-13-2013, 02:27 PM   #10
J mod stands for Jerry mods a engineer who came up with a whole guide on how to build the trans talks about what size to make the holes in the value body for different hp. The shift kits changes the holes and add spring in the value body they are the same but the different is you save money because you don't need to buy the parts just drill the holes to the size and then add new fluid and that all
12:28 AM
