99 block with 95 upper - Mustang Evolution
Old 09-15-2013, 08:03 PM   #1
Hello all first post I have a question I built a 99 block stock all new bearings, new rings, timing chain. Used my 95 heads, intake, flexplate. I know have a vibration at idle but not all all engine speeds and not at all in reverse. Anyone have any ideas.
95convert3.8 is offline   Reply With Quote
Old 09-15-2013, 08:42 PM   #2
davidcseifert's Avatar
Region: Arkansas
I don't remember how the single port internals are balanced but the 99-(~)01 are external balance so you may have the wrong flexplate or harmonic balancer, google the balances lol
blower/new cam soon
Old 09-15-2013, 09:09 PM   #3
samuelsmith's Avatar
Sorry David not the flex plate. Kinda embarrassed to admit this. I put on the wrong flex plate and right harmonic balancer on back in 07, a very stupid mistake. The piston went through the oil pan. It suxed.
99 00 internal
00 later 04 external
Something I will never forget. Got a 9,000 mile engine for $900. What a deal and it looked bran new. I blew it all to hell and back. putting a 99 flex plate on a 3.9 2004.
Old 09-16-2013, 02:28 AM   #4
lemons95's Avatar
I think the 99's are externally balanced, did it have a balance shaft in the lifter valley?
Old 09-16-2013, 02:31 AM   #5
Region: Arkansas
99 00 internal
You have that backwards the later 3.8's are internal they made the swap over sometime 2001from the external balance.
blower/new cam soon
Old 09-16-2013, 03:57 AM   #6
Yes it did have the balance shaft i did see that there are different part numbers for the flexplates between the 95 and 99 blocks but both seem to be 28oz weights. I did use the 95 balancer at first then switched to the 99 mild improvement. I thought maybe the issue may be the new motor mounts i use them for a 95 block the 99 motor mounts where lower profile and wasnt use they would work. I did that it could be i didnt line up the torque converter drain but i havent had time to varify that. When at idle there is no movement or vibration that can be seen looking at the engine and no engine twist when you rev the engine also not sure it matters but.
Old 09-16-2013, 04:17 AM   #7
lemons95's Avatar
Might be the balance shaft 95 3.8 don't have them stock.
Make sure you have the right harmonic balancer.
Old 09-16-2013, 04:26 AM   #8
I am using the 99 blanacer assembly. I did notice the vibration is most noticable when in gear sitting still while driving not bad i know i have some suspension issues nothing serious and before the block swap did have some vibration while driving. I just dont to cause a tranny issue but i have driven the car 166 miles so far and its not getting any worse.
03:41 AM
